Shortened Mazda MX5 gear lever
Mark (smokey mow)
Approx 15-20mm shorter than a standard gear lever.
I had this modified to give a bit better clearance to the dashboard but in the end i opted not to use it. The material was all removed from the centre of the lever where it is at it's largest diameter and then-welded.
£12 and happy to post to you at cost :)
Link to comment
