scott beeland Posted January 26, 2003 Posted January 26, 2003 I might have found a trailer so I can get to SS a little easier. Can someone tell me if the dimensions below sound ok before I think about buying Total length 5.1 m Bed length 4.27 m Width 2.25m Width between wheel runners 1.06m Ta. Scott Oh and its 4 wheeled. Is that better than 2. I found a 2 wheel flatbed trailer also. A bit cheaper! What would you buy?? Quote
Mark Stanton Posted January 26, 2003 Posted January 26, 2003 General consensus seems to be 4 wheel twin axle over 2 wheel single axle If you do go for 2 wheel jobbie look at fitting a sway bar like caravan towers use Simplest way would be take your Westfield measurements and see if it fits onto trailer Check its weight if poss - this needs to be added to Westfield weight and any tools to check full towing/braking weight. Scott - You're going soft before the season has started More room for tent and supplies though Quote
