Paul Ash Posted June 1, 2013 Posted June 1, 2013 JPL 10" cooling fan, used but in perfect working order. Curved blade 650 cfm. Max dims 270mm wide, 282mm x 55mm. Six moulded location points for alternative mounting feet position options and four direct mounting holes in frame. The blade and rotation can be reversed for ’Pusher’ or ’Puller’ set-up. Weight 1.1kg. Max current 5.3 amps. £25.00 plus postage
Gadget Posted June 2, 2013 Posted June 2, 2013 Hi Paul, I'll take it please. PM me your details and I will get a cheque winging your way, or if you are going to the Curborough weekend I can see you there Thanks Ian 1
