questions in the title, i was looking for some longer wheel bolts for the bmw.
From a quick check on the net, normal bolts dependant on wheel have a taper where as wobble bolts have in affect a tapered washer with a slightly bigger centre hole, enabling the bolt to move/wobble inside the washer!
Basically it enables you to fit wheels with a slightly different wheel bolt pattern to the standard ones! Cant see it being too beneficial really sounds a bit scary to me to be honest id stick with standard wheel bolts or alloy wheel bolts!
check this
check this
ah ok, i was looking for some m12x1.5 bolts for the bmw i need some that are 20mm and 15mm longer as ive got some spacers for the wheels and came across these but wondered what the point was?.
It holds the giggling pin on the laughing shaft.
Only if you have a thingy majig fitted on top of the who g ma flip
Dont forget to remove the doobree whatsit first
If this keeps up, I'm moving this to the Tech Talk area...
...using my Administration Transmogrification Hypersonic Transportation Device.
I've had bolts with washers on them before, currently using them! Didn't realise they were called wobble bolts and had so many benefits.
I've just found that when tightening them they feel that they've pinned the wheel in better and less damage to the wheel holes.
I think you'll find its Usaine doing the hundred meters in over ten seconds  ;)
im also fitting a turbo encabulator but am having sinusoidal vibrations....
Allow me to offer my most beneficial perecombobutations
reminds one of the chap who thought his dog should have been an engineer
cos every time he kicked it up the A***
it made a bolt for the door
