OK Guys, a few anomalies here:
Practice 3 on quite a few competitors was in the 25 - 30 seconds so I have omitted them.
Where I could, I have used the last two practice times.
Out of the 16 competitors, 7 failed the cut but it was still only 43.75% failed so this is only just a normal scoring race.
Other than that, it all looked to be good fun and you certainly had the nice weather :d
Linky for the lazy ones
Tiggs
What constitutes failing the cut?
'tis in the Regs Filfan but to make it easy for you, it goes as follows:
If conditions at a round are such that 51% or more of the WSCC entry have times which are 110% or more of the target times, then regulation 1.6(e) will apply.
7 competitors in this event had times over 110% of the target times hence the reason for the comment :)
Tiggs
Ah thanks for that tiggs :)
Tigger, brilliant. You can certainly ignore the 3rd. practice times, first because it was a practice run, not a comptition run, but also because the timing gear was playing up and producing nonsense figures.
I thought that might be the case, either that or your had a rocket up your a**e on the 3rd practise :t-up: :t-up: :laugh:
How did you guess?!! :laugh:  :laugh:  :laugh:
What is it this year? Again, class D or F goes as fast (if not faster) than H!
Still making set up changes to the rear!
That said, I suffered particually badly from coneitus! Might have to leave Mira off of the calender in the future!
Roll on Pembrey!
Del
Those cones have damaged a few cones over the years but it shows you were trying
CONEITUS -  An inability to see the line through a bend because the tarmac is covered in cones. :d
Cones or not I'm happy with my first outing. Maybe after a few more events I will start to look for excuses :d
