Side screens, or just a template
Time has come for the windscreen fitment,and too get it too look right I need some sidescreens to allign it all.
Not sure I actually will ever use them, so even a template would work and I could make it stiffer and utilise that to allign the screen
What have you got ?
AJ
There is a set on ebay at the mo Item number:  111081867913
Anybody ?/?
Right - from my Build manual for a SeiW
Looking at the scuttle sideways on to position the upper bolt hole.  Draw a line on masking tape 110mm up from the base.  It's 140mm along the line from the rebate on the scuttle.  Base of upright is 130mm up from the base.  Do this both sides.  Get the angle right by measuring 1010mm from the inside edge of the top of the windscreen frame to the chassis cross member behind the seats.
I used a black rubber washer, a repair washer and then the nut on each bolt.
HTH.
Rory's Dad
