Bought these on here below is the original advert, went for a different set up in the end.
"Pair of Wilwood Dynalite 4 pot calipers with 1/3 worn Greenstuff pads. Complete with brackets to fit Cortina uprights they are a direct replacement fit for M16 calipers. They have 1.38" pistons which in my experience means that a standard master cylinder will be fine. They are currently spaced for solid discs but also included is most of what you need to space them out for vents. Unfortunately I have misplaced one bridging tube and a bolt  blush.gif but these are readily available from Rally Design."
£150 + postage SOLD
Good evening,
I am slightly interested, but need to save a stash of cash away from Mrs C. So if someone's not taken them off your hands by end of April I'll have them 1st of May.
Cherry
PM sent Shindha
Mark
