Rolling road
16% reductio due to transmission loss maybe a bit conservative. With a LSD it can approach 30%.
30% seems a bit high Norm! even with a LSD
Up to 30%. I've seen evidence of 26% when an engine was dyno'ed then, after fitting was RR'd. Wouldn't take much more friction to get that to 30.
Anyway, 16% is conservative.
Lets agree on 23% then as a half way house
OK. 50% more than 16%   :)
I'm being thick (maybe) but why would an LSD increase the transmission losses?  It only prevents slip between the axles so if both axles are rotating at same speed where do the additional losses come from?
Because they're high friction as the plates are in contact. Roger King reckons that a normal set of gears and an LSD can reduce power at the wheels by up to 30%.
Is that orange line on the graph supposed to be the torque reading?
It appears to show a max of 303 lb ft... if so, it's bollix, unless of course it's a 2 litre turbo diesel ;-)
What about a helical LSD
Or viscous?
its AB near chester. great place ive been there a few times for stuff. im guessing they did the dyno run in 3rd gear so the graph for torque will be wrong wont it?
Still unsure about this.
That's the one. 3rd gear, I think it's 5th for the torque figure, am I right?
What about a Quaife ATB LSD?
