Just to let you all know that the Speed Series scoring will be along the same lines as last year except there will be an additional score sheet for the "Team challenge".
Don't forget to bookmark it (add to your favourites)!!
The drivers list has just been uploaded so you can see what classes you are in and who your competitors are in an easy to read list.
Hope to join you guys this year so watch out for me in the pits :t-up: :t-up: :)
Link to 2013 Speed Series Results
Good work Paul
I must have made a mistake as I should be class f I think. Busa engined car?
Hi David,
There will probably be a few movements when people like yourself discover minor anomalies, hence the reason for posting this.
My list on the web is slightly easier to read as it's categorised.
It's easily resolved David, just drop Nick an email and I will amend this end.
Tiggs
Hi tigger
I do not appear on the list! :(
Although I did sign up late last week.
Hi Onliestsmeg,
Can you check with Nick to see if your entry has been accepted please.
Adding you is a 2 second job, just need to ensure Nick has his records straight too.
Tiggs
Hi David,
Tiggs
Probably better if you can drop me a PM (rather than Nick) as I can access your SS invoices and change any details.  There is an Access query we use for the SS which pulls all the relevant info from your profiles and the SS invoices, so updating them there is the best way to ensure Nick et al have a clean list.
Ooops - my bad!!!
Had generated the invoices but not completed payment :blush:
All sorted now.
Thanks for the exceedingly prompt call Scott.
OK Guys,
Quite a few amendments have been made to the events and drivers list so far, and it's only been up for 1 day.
Can all other drivers please check their classes to ensure they are correct and let Nick or Scott know and I will update as necessary.
Speed Series Competitors List
Tiggs
