Zetec 2.0 Blacktop big valve head
Anybody
Terry
aren't all blacktops big valve heads? in comparision to the silvertop I thought they were bigger.
Steve, the 1.8 engine is coming out and being replaced with a new 2.0 Zetec.
Terry
are the heads different? I thought it was just the bore size of the engine and then the cams?
My 1.8 has hydraulic and the Blacktop is shimmed type, I also think that the valve diameter is different and if you swap say 1.8 for the 2.0 a few galleries are different.
Terry
yea the silvertop 1800 has a different head to the blacktop. as I understand the blacktop has larger valves to the silvertop, and to compensate the blacktop has different pistons to the silvertop allowing the space for the valves.
you can put a silvertop head on a blacktop, but due to the clearance of the valves you can't put a blacktop head on a silvertop.
Do you know if the cam cover from a Silvertop will fit a Blacktop?
I don't believe 1.8 will fit 2.0
But back to the question, anybody got a head?
Terry
