Store Testing In Progress ×
Dommo's Blog
  • entries
    6
  • comments
    16
  • views
    2,305
Well that was exhausting
Dommo
Finally finished fitting the 4-1 manifold after 3 evenings. It gave me a chance to investigate the rattling from the exhaust silencer and it does indeed seem like the cat is breaking up.
Seems like a good excuse for a carbon silencer soon! Save the current silencer for MOT time I think. Anyway, onto fitting the new manifold. With the exhaust system stripped off and weighed because I'm a bit anal (new manifold saves 620g you know), it was time to attack the bodywork once again. I really hate that job. I started off making the hole square, then slowly expanding it towards the front of the car, checking if I could feed the manifold through each time. For those interested, and please don't use these as your starting dimensions, I ended up with a hole around 165mm wide, 120mm tall and 235mm from the front of the tub.
Looks like there is still some filing required on that hole!
It fits quite well, and I did a better job of the silencer this time making sure it wasn't pulling down on the support bobbin. The only thing I'm questioning with myself is if I should grind these welds down a bit.
I think I'll leave it. I'm not chasing every last bhp and it's brand new so doesn't really deserve meddling with!
First impressions are good. I've only had it idling for 10 seconds or so but it already sounds deeper, less raspy. When summer decides to arrive I'll take it for a decent drive.
6 Comments
Recommended Comments
KugaWestie
Good work Dom
I am thinking that I might get a bit of carbon fibre to fit on the side of the body to close the hole up a bit when the manifold is fitted, as it appears that the hole has to be quite large to get the manifold through when fitting?
Link to comment
I had exactly the same thought, but the carbon fibre would have to be relatively wide to keep it symmetrical. Otherwise, it would be obvious what it's there for.
Link to comment
I had the same thought about the welds, but like you, thought best to leave it :)
interesting to see the gap between the manifold and your diagonal chassis brace. mine is very close and may knock under hard driving! have to see. my engine must be a little further back in the chassis.
good work :d
Link to comment
Looks great, Dom.  I shall have to set about mine soon..  It's sitting in the garage calling me!!!  I'll just be so sad to have to butcher that perfect hole I made first time round.  I was proud of that!
Link to comment
Mine arrived just after the Stoneleigh show weekend - looks good.
Hi Mooch - spoke to you at Stoneleigh -  can you remember where you got your 90 degree adapter for speedo cable?
Link to comment
