Meakin's Blog
  • entries
    7
  • comments
    37
  • views
    18,611
Swapping Xflow to Zetec in Narrow Lowline Westfield
Well with pressures of work, I've not had much time to work on the car for a while.
But last weekend (and a bit of this weekend) has allowed me to make some progress. Here we go.
With the bonnet fitting nicely its time to add the ancillaries.
Alternator
Well I had a look to see if I could get the old xflow alternator into the space and the simple answer was "not without a lot of fiddling"
So I bought the alternator and bracket systems from Kit-spares. Okay quite a bit of money but well worth it. Simple o fit and really chuffed with the result. Interestingly though the wiring needed completely changing. The old loom had two permanent lives and a ignition light which was live on ignition. That has had to be completely changed (thanks to westfield-world for helping me work this one out). I use the permanent live connected to the battery (terminal B) the switched live to the 2 terminal and the light connected back to earth. This seems to work, although I shall wait and see.
Air filter.
After lots of discussions on the forums I've decided at this stage to keep it simple. Rather than lost of ducting or cutting the bonnet I have gone for some mesh filters onto the carbs:
There they are, they work well and will at least stop me sucking rocks, birds etc. I know that with it being under the bonnet its not sucking cool direct air but this may be for the future.
Radiator
After reading up on this I decided to go for the polo rad instead of sticking with he old escort one. This took making 4 brackets and a bit of "adjustment" to the mounts on the chassis. The pipe exits are aligned perfectly with the narrow body chassis (sigh) so a little adjustment is needed. I also used flexible pipes to attach the radiator.
I have bought a 95/100 fans switch but will probably keep it on manual to start with. Photo time:
As you can see I've used Silicon pipe (from a roll) for the main stretch rather than a metal pipe to connect all together. (I prefer the fewest amount of connections as possible. The bypass etc connect in a lower pipe so as to get rid of teh overcooling problem (I hope) As can be also seen I've used an xflow temperature sensor in a joiner between the flexible pipe and the silicon hose. Its quite far from the engine though so will have to see how it reads (I suspect a little low) it will also take a while to heat up as it only will get hot water when the thermostat has opened. Looking at other westfields they have the sensor towards the thermostat housing but but again would only be working when the thermostat opens. It would have taken more wire re-routing and space is a bit of a premium at that end so I thought I would see how this arrangement works.
Exhaust
As you all know I have been trying to keep the budget down. So the question of whether or not I could fit the old exhaust system onto the new manifold was always a possibility. Well the answer is: yes it can with a bit a jiggery pokery. My exhaust has two boxes welded together (to meet the IVA sound regs). I'm sure upgraditus will hit and I may change it in the future but budget is tight. So I managed to fit it by making an extra bracket and bolting it in place. In fairness the rear mount is only to support as the main strength comes from the manifold itself. Photo time:
As can be seen it makes it about 6" shorter. This isn't the best angle but so far it looks ok.
Ignition
Last part of this blog. I bought the no-diz ignition module instead of the traditional Megajolt. This was for two reasons: 1) It was cheaper and has more features, and 2) It doesn't need an EDIS ignition module (ie it plugs straight into the coil) This means the whole ignition system is new right from battery to plugs.
I've temporary wired it up to see if I could get the engine running. Wow what a piece of kit. Worked spot on and that was only in 2D mode. A total of 7 wires needed doing (2 to crank sensor on the flywheel) 1 to earth, three to the coil and 1 to a switched live. Piece of cake and engine sounds great. (will need tuning but will do that when I connect the TPS up)
Here is a photo of the temporary layout:
You can see the cooling system pipes, the No-Diz module with its spaghetti connected up temporary. Looks a bit of a mess at the moment but is just a matter of routing and tiding up (you see why earlier I kept the temperature sensor away)
The car has run and sounds great! Things to do now are tidy up, clutch cable and the propshaft.
More to follow
Paul
4 Comments
Recommended Comments
acafrao
Hi paul,
Congrats on the great work. Taking in consideration you have recently fitted a nodiz system and i am looking into this possibility for the near future I thought I would ask you if it was really complicated to fit it with the loom. Also does it have an auto tune option like the megasquirt or not?
Thank you!
Meakin
Hi Acafrao, it was really easy to fit. I've temporary wired it up and it worked out of the box, it was that simple. The guide comes as a pdf and basically it tells you what colour wire to connect where. I haven't connected the TPS yet but its only three wires and again the manual tell you how to work out which one is which although you do need an ohm meter for that, but if you know which one is earth, the signal and the reference wire then you don't need it.
Tuning is either using 2 buttons which are on the box or if you going to 3d then software which connects to you PC via bluetooth. There is an app for android which will give you a digital dash as well but I haven't tried either the software or the app yet.
So far the system is brilliant very small (fat fag packet size) and the instructions are dead easy. I liked the fact that there is no edis module as these are getting rare and you never know what you are buying. By direct ignition you know its all new.
AFAIK there isn't an autotune option although I don't think the megajolt system has either. It has the 3d map type grid and you adjust advance for any of the points using the software. I haven't even connected the TPS yet so will do a blog on tuning it when I have.
The company has been very helpful. I bought an earlier version which has 5v revs output and I needed the 12v kind they have popped the diode pack in the post for me. The new version evidently has it built in with a dip switch to change it.
so far all good, but I will post up more as I do teh "proper wiring" and get the car back on the road.
Hope thats helped
Paul
markS
Hi paul,
Could i ask, what have you used as your throttle cable, as i cant find one with a 90 elbow to go into my bike carbs. Any help much appreciated!
Mark.
