chrisando's Blog
  • entry
    1
  • comments
    5
  • views
    7,516
5 Comments
Recommended Comments
SootySport
I would just start and run the engine, see what happens.  Can't see how you can test everything before it's first run.
chrisando
Thanks Soot1e.
I was thinking along the lines of lights, indicators, wipers, etc. so I can get the dash finally fixed in place - maybe using a low amperage battery just to test that I have made the right connections.
tex
fuses will cover you if you have made a mistake - so id not worry too much - if youv not butchered the harness i cant see there being much problem
FILFAN
just re wired mine and tested most circuits using a small 12v model battery and an amp meter
Captain-Dan
I laid mine all out on a board before putting it in the car - I had done loads of butchery though so it needed a good test. Everything was linked up bit by bit to eliminate any problems before it was in the car. I treated circuits individually until I knew they all worked and then linked them all up together.
