Koso Digital Dash Fitting
  • entries
    5
  • comments
    7
  • views
    41,233
Not going well today
Andy Banks
Oh Dear :cry:
Well I "think" everything is physically as it should be but I'm not having much luck so far.
Today I have traced all the wires and double checked they are reconnected to the correct input on the Koso and I've checked fuses and done a rudimentary check on the immobiliser.
What does work:
  • All lights work as they should and the Koso responds correctly
  • Fuel pump works
  • Starter motor works
What doesn't work:
  • Engine running - turns over but does not fire
  • Ignition warning lamp - I would expect this to come on at least until I get some revs up initially, especially as the battery has been disconnected for a while
Given I cant get the engine to fire then I can't really comment on the temp, rev and fuel gauges on the Koso.
So, not great progress :down:
Next step today is to attempt to trace all wires from where the loom enters the tunnel and check nothing is amiss there - I've had to remove the scuttle to do this but that's the least of my worries.
Oh well...
1 Comment
Recommended Comments
tolf
GOOSED!!!!
