March 2023
Quinten
March 16th, 2023
Spend: £0.00
Continuing on the other side of the car with the spray on arch and arm protection
523230814_2023-03-0615_23_09.thumb.jpg.7fa4b3d32e032efeda54792dd750fbaa.jpg 221893188_2023-03-1115_33_40.thumb.jpg.5ab5fdcc550b7e55e18af60dc408f59c.jpg 102025882_2023-03-1315_25_23.thumb.jpg.80d0f2080075961d5a982963b727d184.jpg
Took again multiple layers of black followed by a couple of layers of gloss FullDip to get good coverage
March 18th, 2023
Spend: £0.00
583514637_2023-03-1316_25_57.thumb.jpg.e805bae702162a86a0b5b3d64789f906.jpg 791300236_2023-03-1416_16_08.thumb.jpg.5bea610a813499ec408d730174eec873.jpg 1054189754_2023-03-1814_42_46.thumb.jpg.0c3487c123ed76d260b2d9f18a4e212a.jpg
Sprayed the steering wheel boss black
March 22nd, 2023
Spend: £15.30
Installed new foam tape for the bonnet to prevent rubbing noises of the body work
March 23rd, 2023
Spend: £0.00
1924476382_2023-03-1814_42_58.thumb.jpg.1e41fc6afa4c2145b2056a8ed272a2ff.jpg 1227954664_2023-03-2315_32_35.thumb.jpg.e1f1da3489522ad013836d863803b891.jpg
Made some aluminium panels to cover the big holes that removing the heater has left.  Sprayed them black using some spray paint I had left over.
Last month: £  4525.78
This month: £    15.30
Total:      £  4541.08
4 Comments
Recommended Comments
Stuart
@Quintenwhat pipe is that you used to bypass the heater?
Stuart
@Quinten yes.  Thank you.  But would you mind awfully telling me exactly which one so I don't have to dismantle mine to measure it up?
Quinten
Sure @Stuart, I got the 16mm internal diameter ones as that is the external diameter of the metal pipes.
