Toys4x4boys Westy Journey
  • entries
    27
  • comments
    55
  • views
    7,368
Too Busy to Play
toys4x4boys
Not much to update,
Big work project has kept me busy evenings and weekends, but I did find a little time to internet shop.
Then before heading off to Milton Keynes ready for an early start Monday, got these wind deflectors fitted.
Need another bend adding at the top to clear the half hood cleanly, hopefully have time to do that next weekend.
Soft Bits for Sevens are also sorting me with some half doors, and a rear tonneau cover.
Be ready for Winter fun drives on no time :)
5 Comments
Recommended Comments
CraigHew
Can't tell conclusively from your pic but have you got a velcro safety strap around your extinguisher?
toys4x4boys
Nope, should I have ?
CraigHew
Clearly no legal requirement but considered "a sensible thing to do"
toys4x4boys
I shall investigate and make it so, cheers.
Dave Eastwood (Gadgetman)
It’s worthwhile.
In heavy front end impacts, heavy fire extinguishers have popped out of there mounting frames before now. Trouble is, they then often have a lot of momentum, and shoot forwards, bounce off the dash or screen, and come right back at the passenger or driver!
One of those ironic injuries, survive the crash unharmed, then end up brained by your own extinguisher!
You can buy general purpose Velcro straps off eBay. They’re then easily enough adapted.
Not the clearest of shots, but you get the idea; the broad Velcro strap is trapped behind the bolted in bracket, so won’t pull free itself. The bracket is bolted on to the rear bulkhead with large spreader washers, (known as repair washers) on the rear side of the panel. These are the same size repair washers as used to secure the seats to the floor, they will not pull through, in an impact. (Least, not in any form of survivable impact :o)
The strap itself, isn’t just Velcro, it had a metal buckle on it that the Velcro strap loops through before securing back on itself. This bit is important, as it makes the straps “hold” massively stronger
