Toys4x4boys Westy Journey
  • entries
    27
  • comments
    55
  • views
    7,369
Catch Can Tme
toys4x4boys
Was pretty much finished messing for the day, and thought I'd just take a look at my heavy breathing catch can issue.
I'd been collecting bit to have a go at it.
This is what I removed
The large  tank ? was bolted to the motor mount, well with 1 bolt anyway, the other lost !
The smaller tank was bolted to the inlet manifold in a heath robinson kind of fashion
And a lot of home made plumbing was evident.
Anyway I just ripped it all out.
I fitted a Burtons blank in place of the home made one, in fairness the home made one had a baffle on it, so this probably wasn't needed, but as I'd removed the old one to check, thought I might as well whilst I had it.
Alloy rocker has 2 unions fitted now.
Block breathes into rocker, rocker breathes into catch tank
Just need to mount the catch tank and vent tomorrow.
Then try it out.
Quick trip to Toolstation turned up a suitable bracket, I wanted the emptying plug easily accessible.
3 Comments
Recommended Comments
Phil J
The idea behind the baffle on the blanking plate is to stop oil being thrown by the redundant fuel pump eccentric on the cam straight at the breather take off - see how it goes you could always change it back easily enough.
toys4x4boys
The Burton one has a baffle too, I wasn't expecting the homebrew one too. So it's all good.
Peter Robinson
Same catch can but I did not use their tube
