pickmaster's Blog engine swap
  • entries
    4
  • comments
    11
  • views
    19,222
Shifter Lights Homemade
pickmaster Andy Lowe
blog-0171491001403774688.jpgI've been asked to put together how I made my shifter lights so here we go
I went to Maplins and bought
A small box
3 x 470k resistors
1x green bright led
1x yellow bright led
1x red bright led
1x small board
1x inline fuse
OVERVIEW
The LEDs are all wired 12v live via the fuse
The earth return of each LED is through a 470k resistor to an earth trigger wire from the ECU
The trigger wires can then be programmed to earth at set RPMs on the ECU
Everything was glued into the box with a hot glue gun
1 Cut board down to size to fit in box
2 lay out components on board and solder
3 drill holes in box for LEDs to poke out
4 Test then glue in place (tie wrap wires to help stop the pulling out)
5 Fit on dash (I used Velcro)
3 Comments
Recommended Comments
C558E54C-5DC4-4FCF-8595-FD391F5A1C27_zps
Kalli
I'll be honest...When I saw the picture, I thought of three man-bits through holes in the wall.
If thats the case, you might want to get the green one looked at.
Tim Reid
Could the same be done with 5 LED's by just adding a further 2?
Any direction as to where to find the ECU trigger earth on a Webber Alpha Ingnition system?
