Store Testing In Progress ×
  • entries
    10
  • comments
    35
  • views
    65,894
IVA passed
JPLS
It would seem i have been a little remiss in keeping this blog up to date - but all things come to an end. So ends this blog
Long story short I passed IVA on Friday 20th June :t-up:
Admittedly it was 2nd attempt, but not dissapointed - I trailered the car for the first appointment on Tuesday and as it passed all the safety bits i.e brakes, steering, build quality etc the opportunity to drive it up on Friday was too good to miss.
Took the car up to Carlisle VOSA and was met by a very friendly team - would recommend if you are remotely close. Andrew was happy to answer any questions and demonstrate and explain the measurements, tests as he undertook his task.
Minor fails on unidentified horn, padding in upper seatbelt harness covers too thin, front steering arm covers (although I did use those supplied from westfield it was considered inadequate), RAC rollbar upper mounts ( I had covered the bolt heads, but the 100mm hemisphere touched the bracket. Note - if the RAC bar is used and there is no evidence of a hood it is considered as exterior. A couple of press studs on the back of the car would have placed the bar as interior and therefore exempt....)
Hand brake travel was excessive - as the brakes had not been bedded in this adjustment went off as the brake test continued.
But the killer was a small fuel leak from the fuel return union that had returned to haunt me - just wet to the touch, but no point pleading for time at this point to remedy the minor faults as this was going to get messy, so took my fail sheet and went home. :cry:
All the minors were simple fixes and hand brake adjusted up nicely to 3 clicks.
Fuel leak required draining a full tank of fuel (topped tank needed for IVA) remaking the seal and refilling. :(
Got some insurance on Chassis number via Adrian Flux, re booked test and drove her back up on Friday.
Passed cleanly - Result. :yes:
And the 200 mile round trip? Wow - fully justified the long hours, bad back, scuffed knuckles, and drained bank account.
Weather perfect, all vital signs good, and with a soudtrack to die for.
Can't wait to get her registered - forms in the post.
http://forum.wscc.co.uk/forum/index.php/gallery/image/2192-westfield-mazda-sdv-ns/
Next trip to Blink for suspension setup and some headwork.
Need a new project.
3 Comments
Recommended Comments
KugaWestie
Yep, well done.
Now the upgraditus will kick in
Link to comment
Captain Colonial
Congrats and well done, hopefully the advice from the reprobates in here was an assistance to you!
Upgrades, here you come!
Link to comment
