KugaWestie Posted February 2, 2018 Share Posted February 2, 2018 On Wednesday I parked my car at a job we are working on, and got a parking ticket, or PCN as they are called now. An ON STREET Parking charge I have contested this one as I fail to see how I was in the wrong?! Quote Link to comment Share on other sites More sharing options...
Dommo Posted February 2, 2018 Share Posted February 2, 2018 Is that a path or land owned by the premises? The warden may have interpreted it as a path? Though they should also have recognised that it's a BMW and so can park anywhere anyway. Them's the rules. Quote Link to comment Share on other sites More sharing options...
KugaWestie Posted February 2, 2018 Author Share Posted February 2, 2018 5 minutes ago, Dommo said: Is that a path or land owned by the premises? The warden may have interpreted it as a path? Though they should also have recognised that it's a BMW and so can park anywhere anyway. Them's the rules. I cant see how it can be deemed as path, as it does not continue along the fence line. It is also dropped kerb where I parked. The double yellows dive back into the fence line at both ends of the car/van as there are entrance gates Quote Link to comment Share on other sites More sharing options...
SootySport Posted February 2, 2018 Share Posted February 2, 2018 You parked on a footpath which is wrong. The fact that there are dropped kerbs doesn't come into it. Quote Link to comment Share on other sites More sharing options...
KugaWestie Posted February 2, 2018 Author Share Posted February 2, 2018 11 minutes ago, SootySport said: You parked on a footpath which is wrong. The fact that there are dropped kerbs doesn't come into it. I cant see that it can be deemed a footpath Bernie, it does not go anywhere or come from anywhere Quote Link to comment Share on other sites More sharing options...
Kevin (Mr T) Posted February 2, 2018 Share Posted February 2, 2018 My understanding is that the double yellows follow the line of the "road", so the area inside would be deemed footpath, whether it leads anywhere of not. Quote Link to comment Share on other sites More sharing options...
toys4x4boys Posted February 2, 2018 Share Posted February 2, 2018 The fact it has yellow lines around it, probably dictates it being a footpath. Something along the lines of, if it was a roadway, the yellow lines would be along the fence. Vehicles exiting the gateway, now have to edge out further to see past the car and van. So the doesn't come from or go anywhere doesn't matter as it was serving a purpose. But it's all guesswork, if you appeal, they will let you know. Quote Link to comment Share on other sites More sharing options...
KugaWestie Posted February 2, 2018 Author Share Posted February 2, 2018 My problem with it is that it appears to be a parking area, dropped kerbs, double yellows going around it. I am not in the habit of parking illegally and have never received a parking ticket before. If I am wrong I have no problem with paying the fine, but I do think it is very misleading if I am wrong My argument is that I received a PCN for "on street parking", and I am not parked on the street Quote Link to comment Share on other sites More sharing options...
KugaWestie Posted February 2, 2018 Author Share Posted February 2, 2018 Taken from the Highway Code on the Gov website - I was not in London, this was an industrial estate. If it is deemed as pavement it says should not do so unless signs permit. That does not mean cannot Rule 244 You MUST NOT park partially or wholly on the pavement in London, and should not do so elsewhere unless signs permit it. Parking on the pavement can obstruct and seriously inconvenience pedestrians, people in wheelchairs or with visual impairments and people with prams or pushchairs. Quote Link to comment Share on other sites More sharing options...
toys4x4boys Posted February 2, 2018 Share Posted February 2, 2018 I'm sure I saw a piece on dropped curbs recently. They only allow you to cross the pathway to a parking spot not on that pathway. So in theory, drop curb outside your own house, you cant park in it blocking the pavement, just use it as a way to get to your drive on your land. So a dropped curb anywhere else, probably has the same rules apply. Quote Link to comment Share on other sites More sharing options...
Dommo Posted February 2, 2018 Share Posted February 2, 2018 Assuming it's not part of the factory. Part of my front drive abuts the road with a dropped kerb and no footpath and being my property it's perfectly fine for me to park there. The double yellow lines cover to the property boundary so it's where that boundary is that would be the key indicator. Quote Link to comment Share on other sites More sharing options...
KugaWestie Posted February 2, 2018 Author Share Posted February 2, 2018 6 minutes ago, toys4x4boys said: I'm sure I saw a piece on dropped curbs recently. They only allow you to cross the pathway to a parking spot not on that pathway. So in theory, drop curb outside your own house, you cant park in it blocking the pavement, just use it as a way to get to your drive on your land. So a dropped curb anywhere else, probably has the same rules apply. My defence to that would be as the post above if it is deemed to be a pathway, which I don't believe it is. Be interesting to see what the response comes back as Quote Link to comment Share on other sites More sharing options...
KugaWestie Posted February 2, 2018 Author Share Posted February 2, 2018 3 minutes ago, Dommo said: Assuming it's not part of the factory. Part of my front drive abuts the road with a dropped kerb and no footpath and being my property it's perfectly fine for me to park there. The double yellow lines cover to the property boundary so it's where that boundary is that would be the key indicator. Does it say anywhere (Highway Code) double yellow lines cover to the property boundary? I received an "on street" parking fine, and I am not parked on the street or yellow lines Quote Link to comment Share on other sites More sharing options...
John Loudon - Sponsorship Liaison Posted February 2, 2018 Share Posted February 2, 2018 Out of interest, do you know if the vehicles shown on the left of your arial picture also got a ticket? Quote Link to comment Share on other sites More sharing options...
KugaWestie Posted February 2, 2018 Author Share Posted February 2, 2018 2 minutes ago, John said: Out of interest, do you know if the vehicles shown on the left of your arial picture also got a ticket? No idea as the aerial picture was downloaded from google, so taken at a different time to when I parked there Quote Link to comment Share on other sites More sharing options...
