Mark (smokey mow) Posted February 25, 2013 Posted February 25, 2013 With the pace picking up on the new project I really need this out of my way, I am therefore listing it for sale for one final time before it goes into storage. I have amended the description, removing some of the parts that were previously included so as to reduce the base price and offer a massive price reduction. Please note that this base price is non-negotiable however I am more than happy to discuss prices if you are also looking to buy any of the other body panels or running gear I also have available separately for this car. I was building this car for no other purpose than the enjoyment of doing so and it had always been my intention to sell the car on when it was completed. The rebuild of the car and its history in my ownership is well documented in my rebuild thread (see link below), so it's only for me to describe further what will be included in this sale. http://forum.wscc.co.uk/forum/index.php/topic/88905-smokey’s-narrow-rebuild/?p=893554 The chassis is a 1990 SE Live axle Narrow body. It is not road registered, and to the best of my knowledge has spent its whole life as a track and race car. It was my intention to rebuild the car as a cheap track-day toy. I bought her in 2011 from the previous owner who was breaking her following an on-track accident. The damage was limited to the front of the chassis and engine bay tubes, which also because of previous modifications were cut out by me and replaced with new. All the photos of this work are available in my build blog. The chassis comes with all the necessary major parts with the exception of a few nuts and bolts to complete this to a rolling chassis stage. The front wishbones have been fitted only for the photographs but have been removed again for ease of storage. The nuts for the front suspension ball joints are missing and I also don't have any steering track rod ends. Also included in the sale will be copies of all purchase invoices, receipts, and build photographs which would be required should you decided to IVA the car. Chassis Transmission tunnel has been widened from 9" to 12" to accommodate an Mx5 gearbox. Chassis was degreased and undercoated with grey POR-15 and with 2 topcoats of satin black. New mounting bosses for 4-point harnesses welded on. Floor is panelled in 2.0mm NS4 aluminium, back panel and tunnel in 1.2mm 1050a aluminium. 3 additional unfitted panels will also be provided for the cockpit shoulder panels and scuttle top panel. The copper brake lines are installed and fitted with unions, 3 flexible brake pipes are included. A short length of brake pipe still needs making up for the rear axle. No fuel lines are fitted or included. Steering Brand new (from Westfield) upper steering column with lock and 2 keys. A bracket still needs making to attach the top of the steering column to the dash hoop. Mountney classic steering wheel with Allegro boss and crashpad. Lower steering column. Mk2 Escort steering rack and rack mounts. Bodywork Wide body detachable arch tub cut and modified for fitment to a narrow chassis. Rear of tub still needs either fibre-glassing together, or joining with an aluminium flange. Narrow body scuttle (in need of painting) Front suspension Cortina uprights, fitted with alloy hubs. M16 calipers with Ferodo DS2500 pads and solid discs Cortina bottom balljoints (look new but one has a small tear in the gator) Transit top balljoints Spax front dampers with springs (the dampers need replacing, but springs are in good condition and useable) Standard track front wishbones refurbished and fitted with new bushes. Rear suspension Escort live axle fitted with Westfield 4-link brackets. 9" drum brakes, all cleaned and rebuilt. 3.9 open diff Trailing arms and panhard rod, all fitted with new metalastic bushes. Gaz rear dampers are brand new, and come with dyno plots and springs. Handbrake, and cables are all fitted and working. Other Stuff Westfield wide Race Seat and mounting frame. Narrow body Westfield "RAC" braced rollbar with back stays. Set of 5-off capri laser (similar to RS) alloys with tyres (tyres all need replacing) Full set of correct open wheel nuts. The rolling chassis parts as described above I am offering for £1250 no offers The following parts are not included but I do have available separately Brand new yellow high-line narrow body bonnet (still in delivery crate) Brand new black high-line narrow body nose cone Full set of Westfield Pedals Tandem brake master cylinder Brand new Polo Radiator and Westfield mounting brackets 1600 MX5 engine and gearbox Fabricated Westfield engine and gearbox mounts to suit MX5 engine Westfield Exhaust Manifold for Mazda engine Pair of new wide body detachable rear arches in Black The car is located on the Essex/Suffolk boarder just north of Colchester. I have a trailer and may be willing to deliver locally at cost depending on distance and location. I can be contacted by PM or email to wsccessex@btinternet.com any questions please ask Thanks for looking. Mark 1
User0083 Posted February 25, 2013 Posted February 25, 2013 He'll see it soon... James is looking for a £5k-£7k car and with a bit of work this could be what he wants!
KugaWestie Posted February 25, 2013 Posted February 25, 2013 Never thought I would see the day - this will be a good buy for someone
alexander72 Posted February 25, 2013 Posted February 25, 2013 Cherry, you beat me to it. Mark, that must have been a tough call as that is a lovely looking chassis. I will speak to my mate Steve (who needs to build a garage) and see if he is interested. What a cracking opportunity of a great chassis well sorted already. Cheers
Mark (smokey mow) Posted February 25, 2013 Author Posted February 25, 2013 He'll see it soon... James is looking for a £5k-£7k car and with a bit of work this could be what he wants! Never thought I would see the day - this will be a good buy for someone Cherry, you beat me to it. Mark, that must have been a tough call as that is a lovely looking chassis. I will speak to my mate Steve (who needs to build a garage) and see if he is interested. What a cracking opportunity of a great chassis well sorted already. Cheers Thanks Guys if it wasn't for the JW4 then I wouldn't be selling, but lacking in both space and time I have to be realisitic about have many projects I have
User0083 Posted February 25, 2013 Posted February 25, 2013 Just pm'd you James, but error msg came up, you can't receive new pm's! Probably need to delete some. Engine/gearbox £500 Cycle wings, bonnet, nose cone £300 Dash/dials £250 Rough guesses for used stuff from here and eBay. Be a bit of work and a decent project for someone on a budget! I'm tempted to buy it and transfer what I can from my wide boy, but think I'm best just leaving it!
darren paul creed Posted March 19, 2013 Posted March 19, 2013 Hi was just looking for bare frame to trasfer from my narrow
Mark (smokey mow) Posted April 21, 2013 Author Posted April 21, 2013 BTTT with a Pre-Stoneleigh price reduction to £1750 I'm happy to incude as few or as many parts as needed to tailor a package that suits individual requirements, the price therefore is negotiable up or down on that basis
Mark (smokey mow) Posted May 23, 2013 Author Posted May 23, 2013 BTTT with massive price reduction With the pace picking up on the new project I really need this out of my way, I am therefore listing it for sale for one final time before it goes into storage. I have amended the description, removing some of the parts that were previously included so as to reduce the base price and offer a massive price reduction. Please note that this base price is non-negotiable however I am more than happy to discuss prices if you are also looking to buy any of the other body panels or running gear I also have available separately for this car.
CRAIGR Posted May 23, 2013 Posted May 23, 2013 Bargain !!! Must resist ....Someone hurry up and buy this .
Burlers Posted May 23, 2013 Posted May 23, 2013 Go on Craig, you want it, you NEED it, go on Craig, we're all rooting for you.. You know you want to
alexander72 Posted May 23, 2013 Posted May 23, 2013 I'm like Will iAm hovering over the "buy it now button" on this one.....
Mark (smokey mow) Posted May 29, 2013 Author Posted May 29, 2013 Now on eBay http://www.ebay.co.uk/itm/130919067646
alexander72 Posted May 29, 2013 Posted May 29, 2013 Smokey - I will PM you tomorrow mate. up to my neck in it right now...
Mark (smokey mow) Posted May 29, 2013 Author Posted May 29, 2013 No probs or feel free to give me a call anytime if its easier
