Wanted: Lightweight Zetec Flywheel
dhutch
What have you got?
- Not looking for anything superlight, and am not sure what I think about machined down cast flywheels, but open to consideration.
Daniel
Link to comment
Get yourself a late cvh efi fw daniel
Just over 6 kg and have marks for crank sensor
Same bolt pattern , just drill out to 11mm
Clutch bts the same
I use one - pickup is amazing
Link to comment
I have heard this before, even as crude as people using a piston drill to open out the holes.
How can I tell what I am buying when looking on ebay? Is it for instance the case that any CVH with timing marks will be a late efi spec one? Is the ring gear on this correct for rwd setup? What clutch does it take? Anything else to look out for?
Daniel
Link to comment
A pillar drill will open the hole up
The steel isnt hard
Bolt pattern is the same as 1800 zetec so you use a 1.6/1.8 early mondeo clutch - that will have the same splines as a type 9
Or have it drilles to take a pinto clutch
Ring gear is the same so re use starter
The fw will have the timing marks on the back
Ime sure ive got photos somewhere-ille dig them out
Link to comment
Here you go - ive even found one for you
Ebay 282018180832
Link to comment
The steel isnt hard
Ebay 282018180832
Thank you.
Will that bolt pattern match with the CVH flywheel (which I understand my be from a fwd cvh ?) I currently have on old engine? Or did they change throughout the years?
Daniel
Link to comment
That will fit fine once you have corrected the hole size , as Steve says that is the only issue
Link to comment
Link to comment
I have a cvh flywheel drilled to fit Zetec if your interested
I just need to dig it out
Link to comment
PM sent.
Link to comment
