Crash test dummy Posted June 29, 2015 Share Posted June 29, 2015 For sale on behalf of a friend, a 225bhp XE with the following spec: Forged Omega pistons, Fidanza aluminium flywheel, Helix HD clutch cover and plate to fit 23-1 spline Ford gearbox, steel inner oil pump gears, fully ported head, Cometic steel head gasket, ARP head studs, baffled QED wet sump, twin 45's Webers that are jetted for the engine, modified VW ignition ecu, distributor and coil. Crank sensor, water sensors, Glyco bearings, Bilas mechanical profile 296's cams with double springs, verniers, solid followers, aluminium crank pulley, polished valve cover, dyno printout available. Cam details here: http://www.dbilas-shop.com/Products/Performance-camshafts/Opel-Vauxhall/2-0-16V-DOHC-C20XE/mechanical/New-camshafts/-Opel-Vauxhall-2-0-16V-DOHC-C20XE-Performance-camshafts::5257.html To get this package up and running in a Westfield all you would need is an inlet manifold and an exhaust system. Pictures available on request. £2199.00 Link to comment Share on other sites More sharing options...
Stevec33 Posted July 1, 2015 Share Posted July 1, 2015 Message sent Link to comment Share on other sites More sharing options...
Crash test dummy Posted July 2, 2015 Author Share Posted July 2, 2015 Replied. Link to comment Share on other sites More sharing options...
