Andy665's SEiGHT
  • entries
    8
  • comment
    1
  • views
    4,399
Few more jobs completed
andy665
Few more jobs completed.
Replaced the old carbon effect front wings with 100% full carbon fibre items from Carbon NV, fabulous quality at sensible prices. Decided on the CSR style wings because the extra moulding lines at the top of the wing provide a slight but noticeable increase in rigidity.
Really wanted to save the old wings as I could have sold them on but they were bonded to the brackets and the one thing I can say about Tiger seal is that once its set nothing is coming free too easily.
The bracket is mounted to the front suspension by three bolts but cannot be entirely freed from the car unless the wing is removed from the bracket - after a while of attempted and failed efforts to remove the wing from the bracket with no damage being done to the wing I gave up and cut the wing across its width, thus enabling me to remove the bracket / wing from the car and getting good purchase on the wing to break it free.
Once separated it was a laborious job to remove all the existing sealant from the bracket, rub down and re-paint (so much more satisfying and so much cheaper than replacing them)
Position the new wings was relatively straightforward, couple of key measurements taken to ensure that each side was identical then a single run of Tiger seal on each "leg" of the bracket was enough to hold each wing in position.
24 hours to allow the sealant to harden off and then more seal applied to fill in any gaps and job done
Only downside to the new wings is that they fit so closely that to remove the front wheel now requires the wing bracket to be undone and moved slightly up and across - fortunately access is good and only tales a couple of mins per side
Before
After
Second job was to balance the Jenvey throttle bodies, I had a feeling that they were out of balance side to side and despite reading up on the matter I was slightly concerned I might make things worse.
Having acquired a synchrometer to measure the pressure it was a case of winding down the main idle bleed screw, measuring across all 8 trumpets and then adjusting each pair in sequence, once equalised the main idle could be adjusted.
I may have been lucky but it was not a difficult job and the car responds to the throttle much more sharply and has got the V8 burble it was missing, they were definitely out of balance before and whilst maybe not 100% balanced now they are not far away
  • Like 4
0 Comments
Recommended Comments
There are no comments to display.
