Help - Battery Warning Lamp On Permenantly
Andy Banks
 Share
Hello :)
So my Battery Warning Light is on - all the time! Has been for a few months if I'm honest.
Checked my wiring and voltages from alternator and all seems ok. I have no probs starting and she runs just fine, stops and starts on the button. If I leave the lights on (which I did for 20mins) the battery is flat so I stick the charger back on for 30mins and off she goes no probs. I suspect if I leave the charger off over a couple of days it will also be flat as the clock and imobiliser will take a bit of juice. Its a little Odyssey 25 of some flavour.
I have a Halfrauds charger/conditioner for regular and gel batteries, it's pretty much always connected and has not let me down (yet...). So now it stays red charging and never goes to green maintenance anymore.
I've not changed anything electrical wise and I can't see anything obvious.
Do I need to dig further in the electrics, alternator, charger or do I have worn out battery?
Ignition off | clock ticking | immobiliser on
Batt 13.31v
Alternator 13.31v
Batt to Gnd - Good
Alternator to Gnd - Good
Ignition on | engine running | clock ticking
Batt 12.82v
Alternator 12.85v fluctuation but no lowe 12.83v
Batt to Gnd - Good
Thanks.
Link to comment
When you say battery warning light is on all the time do you mean even when the ignition is off? :oops:
I'd expect 14v when the alternator was charging and engine running and everything was tip top...
Link to comment
Looks like the alternator is not charging
If you run engine for 15 mins and recheck batt voltage with engine off it will be less than you started with but should be more if alternator is working
That would explain why your battery light is on when running cos its not charging
Link to comment
Sorry, no, only when ignition is on and/or engine running.
Link to comment
Right, I'll test that tomorrow and let you know.
Link to comment
One more thing... I've been out and about this evening driving for 20-30mins stopping for an hour, driving for 10mins, stopping for 10, driving for 10, stopping for 10 driving for 10. All this with lights on. Last time I tried that with a faulty Alternator ground wire the battery just gave up and the car died. No such problems here so there must be some sort of charge coming off the alternator. As I undertstand it then (limited knowledge) the alternator is just not giving enough which causes the flow across the warning light making light up.
That make any sense?
So I'll try the above and I'll also try and dig out a spare alternator from somewhere.
Link to comment
12.8 v is not good I would say the alternator is pooped. When I got my car the batt light was not connected. When plugged in it came on and never went out. I also had lower voltage charging than wen engine off.
Put on a spare alternator I had lying around (landrover defender) and all was then cured
Link to comment
What type of alternator do you have, is it a small denso type which may have a lower output amperage, voltage shouldn't be lower though, may or may not be relevant. Is it possible that you are using more than you are generating in your short runs. To recover after an engine start alone will take a short while. The charging light being on though is normally the sign that a charge isn't reaching the battery as far as I know. Having a lower voltage at the battery with the engine running is not good. Did it function correctly prior to this warning light issue, have you altered or disturbed any of the wiring and checked all your connections and cables.
I noticed my indicators where flashing quicker than normal the other day and it was the alternator not charging the battery, a connection had worked loose on the alternator, one of the small ones :cry: and I was running off the battery alone and running it down. Thankfully the battery is in good condition and I was only using LED lights, fuel pump and ignition. When checked for charging my voltages rose from when the engine was stopped to running and my ignition warning light was working again.
Bob :(
Link to comment
Get the battery tested at a Kwik fit type place they will do it for free and tell you if all the cells are ok
Your alternator is dragging the voltage of the battery down with the engine running
Just had exactly the same with my car, Westfield sent me a new alternator- Fixed.
If it is the alternator and you have a wee small battery, all of these charge discharge cycles won't help it's lifespan
Any reputable auto electrician who does starter motor & alternator diagnostics will be able to sort the alternator. £50 ish repair, they're easy to take off.
You could have the alternator & battery off, tested and diagnosed by lunch time...
Bob
Link to comment
Thanks Gents. Current Alternator is Dunnell Enduro Spec.
I've disconnected the charger and I'm going to do the 15min test and I'll probably swap the alternator this afternoon and go for a run.
Link to comment
Your alternator is not charging properly. The fact you can start and drive it is because you are trickle charging the battery when you are parked up and the electrics are being run mostly by the battery when you are driving. The battery should measure 14+volts when car is idling and you connect a voltmeter across the + and - terminals. So just buy a new alternator or re-furbed one.
Link to comment
New alternator seems the way to go. I have a spare so will swap out tomorrow.
Link to comment
Batt 13.31v
Alternator 13.31v
Batt to Gnd - Good
Check the battery too! A fully charged battery should show 12.6 volts. At 12.3 volts it's 50% goosed and needs replacing. I have no idea how a battery can hold 13.31 volts with all electricals switched off except for a clock draining a small amount of current as the chemicals inside the battery simply cannot generate this amount of voltage when the battery is "at rest"...
Link to comment
  • 2 weeks later...
Of course that does seem odd. Me being a numpty reading the multimeter properly or maybe I had the blasted charger plugged in at the time :o Oh dear...
Link to comment
OK, so I still think the battery may still be goosed or the alternator is still playing up. However, I found that the lamp wire was (once I got the circuit diag from Dunnell) plugged in the wrong spade terminal on the alternator initially.
So now the light is not on but still a bit of testing to do...
Link to comment
 Share
