Frosty
Guide to wishbone bushes
bollockybill
A paint line on nuts and bolts serves two purposes. First, apply after torquing the bolt, confirms that you have tightened it. Second, will show if the bolt is coming loose with just a visual inspection.
Also handy for IVA inspection, looks a better job and hopefully impresses the inspector.
  • Like 3
Share this post
Link to post
Chris Broster - Bristol & Bath AO
10 hours ago, Andrzej said:
Is it "normal" in Westfield construction that some bolts/nuts loosen when driving ? I have to check every one of them after every trackday ? Front suspension checked and it is tight so far.  But in rear few loose bolts  / nuts . Strange. The nuts are nyloc type of course. Maybe partialy the cause was oil mist from differential (not sure where in diff the leak is , but for sure  it is from diff) , so :  little oil  plus  vibrations...
I know I have to change to new nuts. The bolts to diff I used some blue  thread glue , just in case.
Simple answer would be no - however, as always the mechanics of fixed and moving parts adds a little 'magic' that can make the tightest loose and the loosest tight!  As mentioned above, torque break paint is a good visual and thread lock will help BUT the best way to prevent loosening (and to identify it if it is happening) is to positively lock the nut using a mechanical lock - in all cases ensuring that the assembled nut and bolt are 'in safety' by having at least 2 clear threads showing outside the nut:
  2. Castle Nut and Split pin 1769709426_castlenut.jpg.373d9ae3e75e57031c6d1fd2d3bffc06.jpg668160406_splitpin.jpg.366bd368fc6748f4670c35289e4737e7.jpg
  3. Jam/Lock Nut 655775799_jamlocknut.jpg.2027b3519aef67ef8380bfc2b29e13fc.jpg
  4. Wire locking 1895877917_wirelock.jpg.14841358216defcb86c6f902fd9fe7b1.jpgwirelock2.jpg.3ed35f81f74bc445190bdb46e9557172.jpgwirelock3.jpg.b9ad33b91fe74a77fb51c125f50648f5.jpg
Of these, number 3 is the easiest if you have enough thread and space to operate, followed by number 1 the tab washer.
Number 2 requires the bolt to be drilled once the nut is torqued correctly and hence can lead to increased consumption of bolts if items are frequently removed/reassembled.
Number 4 is the preferred method for critical parts that have frequent removal or are difficult to check.
If you are using the car on track mainly and driving hard then I'd want some form of mechanical locking.
Share this post
Link to post
Dave Eastwood (Gadgetman) - Club Secretary
Personally I wouldn't even count no 3 in a real world list of mechanically secured fasteners - seen them creep loose too often for that. Lock tabs, split pins and lock wiring still out weigh every other method in my mind.
Vibration and heat cycling can be harsh bed fellows when it comes to fasters creeping under load, but there are other elements too; for instance if the surface the fasteners head bears down on, isn't perfectly flush and perpendicular to the shank, the uneven surface it bears down on, can cause issues.
Share this post
Link to post
KenP
Also if you are using a tab washer the washer it's self must be prevented from turning. This can be done having a tab on it's inner diameter that fits in a slot on the bolt, a tab on the outer that can be bent around a fixed part or a double tab washer that works against 2 different nut as often found on brake mounting bolts.  Some good examples here https://www.seastrom-mfg.com/washers_tab_key_notch.aspx
Share this post
Link to post
Snags
I have been using Nord Lock washers this year for the first time and they seem to be working well in both vibration and high heat situations. Only draw back with them is that when you undo they over torque the fixing so use on aluminium threads is dubious. Main area of use has been turbo and drive shafts where I have had problems with security, my suspension is too new to have experienced loosening but may look to these if do.
Other advantage with Nord Lock is that they are reusable whereas nylocs are advised to be used only once and some other locking systems are very difficult to get  torqued accurately.
Share this post
Link to post
Andrzej
Good points, the paint for visual check rather than checking with torque wrench seems like a god practice. The other solutions also worth trying out depending on bolted elements.
Share this post
Link to post
Stagnite
Excellent description of how bushes work.
Does that mean that a squeaky road car rubber bush is caused by the rubber separating from either the crush tube or outer casing?
a description of a rose type bush will be good.
Thank you for your time creating this useful article.
Neville
Share this post
Link to post
Andrzej
@Snags , thank You for the Nord Lock suggestion. I have to find it and try too, yesterday I discovered loose driveshaft nuts (!) and loose (almost full out) screw to quick shift  adapter to MT75   (the first with nyloc, second with spring-washers) .
Share this post
Link to post
Dommo
So, if I wanted to replace my bushes because at least one of my wishbones is showing front-back movement, are these the ones?
https://parts.westfield-sportscars.co.uk/index.php?route=product/product&product_id=899
And are they going to be slightly more interesting to fit that the ones that were supplied with my kit?
Share this post
Link to post
SootySport
Neville
The squeak could be caused by rubber seperating or seized bolt going through the bush, or the bolt turning when the wishbone moves.   Copper grrease prevents this when fitting them in the first place.
Share this post
Link to post
No, the original post is correct If replacing with Polybushes, you must use the two metalstic bushes shown in the package; they fit on the Outer,  lower rear suspension arm eyelets, opposite the Rose joints. Without them, the more solid Powerflex bushes would simply jam up as soon as you started adjusting the Rose joints beyond the poly bushes movement range. (Used to be the same with the old Nylon bushes too, you had to retain two metalastic bushes there, as well.)
Share this post
Link to post
Dommo
How does that translate to the Mazda set up which doesn't have the single rose joint?
Share this post
Link to post
I would be very wary of putting anything but metalastics in those two lower end fittings, as when you screw them in/out to set the toe, I'd suspect the Westfield poly bushes might bind.
(I've fitted a set to the Honda car, but am yet to road test them. Statically on the bench though, there seems very little "give").
I would certainly speak to the factory before ordering, to see what the score is.
Share this post
Link to post
Dommo
Yep, that's beginning to make sense in my head. From memory, I don't think those two fittings were quite true which would give the bushes a harder time. Be interesting to revisit after, yikes, 7 years!
Thanks!
Share this post
Link to post
