NDS Posted July 12, 2011 Posted July 12, 2011 Workshop Clearance Cortina Alloy hubs – New with 45mm long studs with 12 x 1.5mm threads with 60 degree wheel nuts 19mmA/F NEW cost £62.00 each £80 for the pair Ralloy Dry sump tank – 6R4 type Ralloy part number RAL119 Length 20cm x Width 20cm height 41cm with screw top (cost £194.60) Used £105.00 Narrow SE Scuttle BRG – used £35.00 Narrow SE boot box BRG – used £ 15.00 SOLD Narrow SE Carbon Mods dash in pre-preg carbon – new £60.00 SOLDMick made pre-preg carbon side panels – new £110.00 (these are not suitable for early chassis due to the height differences (15mm) 4 x Minilite copies – Four of Yokohamas Advan A048 in Medium soft 205 x60 x 13” ( note they are road legal) No idea the ET on the wheels they came on my SE. 1990 £ 400.00 Vauxhall Red top parts: Titan dry sump kit complete only dry fitted to the engine – complete with pump, pump drive belts ,pulleys front cover. Cost over £1200 - £650. Oil pump standard (new) £50.00 Oil pump with up rated gears and pressure relief valve oil oil filter blanking cap – Cost of £500 from SBD £300.00 Red top engine removed from Calibra Cocast head – 101K miles complete with starter alternator ,flywheel, and inlet manifold coil packs . £400.00 Bare block – used for mocking up - £45.00 Crankshaft – standard - £50.00 Exhaust Manifold – bonnet existing manufactured by Tony Law 4-1 A WORK OF ART! With re-packable silencer in mild steel. £400.00 With the exception of the engine all the parts can be delivered by TNT – next day service. The engine can be palletised But a forklift will be required for unloading. Any questions please do not hesitate to contact me. Neil 01738 550005
NDS Posted July 13, 2011 Author Posted July 13, 2011 Thanks for all the enquires ! - Must be the right time with the right bit! I will get back to all the e-mails/phone messages. The wheels and tyres ; my mistake Four of Yokohamas Advan A048 in Medium soft 205 x60 x 13” ( note they are road legal) No idea the ET on the wheels they came on my SE. 1990 thanks Neil
