Duratec install bits
Due to plans changing, I have several Duratec items for sale.  All bits have been fitted to the car, but not driven. Used only for approx 1 hour of engine running time. A few bits may have a few light scuffs where they've been on and off the engine and around the garage, but all in good working order.
- Raceline exhaust side alternator mounting kit (two brackets, small idler and associated bolts) - £50
- Edge lightweight 40amp alternator (model CM550) to suit the above - £110 (one of the small bits of the birdcage casting has broken off, but as new apart from that)
- Raceline/Raceco lightweight steel flywheel for 8 1/2" clutch (4.75 kg) - £150 (will be removed from the car this weekend)
- AP Racing 8 1/2" heavy duty clutch kit (CP 5905-1 cover, CP 5352 plate) - £150 (as above)
- Duratec mechanical 82o thermosat (brand new, not fitted) - £25
Items can be picked up, if you're near Peterborough, or I can estimate a postage cost and refund any subsequent overestimate. Payment by bank transfer or cheque preferred. If no takers within 7 days, I'll probably put on fleabay, so please let me know asap if interested.
Cheers, Mark
Hi there
Just stumbled across your post - you still a westy owner?
I am just up the road from you - if you fancy a trot out or meeting up for one of the local monthly meets let me know
Cleggy
Hello Cleggy
Seen a few of your posts and 'have been keeping tabs of some of the Cambs events etc..
Yes, still got the car and desparately trying to get back on the road following an engine swap that's taken forever to get finished. I've got Liam's old car and, if I'm hoping to be mobile again by the end of the month, so would like to get involved in the local meets/runs etc.. Once the end looks in sight (before it starts snowing I hope!) I hope to get out and meet a few of the Cambs crowd, so cheers for the message.
Mark
