Hammy Posted June 25, 2011 Posted June 25, 2011 Alloy box - to Suit ECU £10 Alloy box to suit Battery 228 *83mm inside measurement. Needs clean up but good £12.50 Facet 40015 fuel pump - NEW! £20 4 off 36mm chokes -weber I think, S/H £20 the lot Top hose fitting temp switch adpater S/H , will clean up ok £10 Facet Fuel pump rusty but works -handy track day spare £5 Westfield type rev light lens, no cracks £2 Bolt & spacer -to fit trigger wheel to fornt pulley £2.50
stephenh Posted June 25, 2011 Posted June 25, 2011 Hi Hammy; whats the difference between the alloy box to fit the ecu, and the alloy box to fit a battery? I might be interested in the latter.
Hammy Posted June 25, 2011 Author Posted June 25, 2011 Nothing but size; the ECU box is 171 *48 slot size
