westfieldvx Posted June 15, 2011 Posted June 15, 2011 Here is some more stuff left over from my Westfield development. Most of the items are either new or only been used a couple of times. I have pictures of most so if you contact me I can email them to you. You can also phone/text me Tony on 07760 285674. I'm based near Bournemouth so postage costs assume you are mainland. You can also pick up if you want. Indicator lamps (orange round ones) NEW £12 pair inc postage Indicator repeaters (oval orange) NEW £8 pair inc postage Ramair filter suit twin carbs 120mm deep 420mm long bit tatty but no holes. no back plate £16 inc postage Coil springs 2.25"dia 9" open 200lb little used pair £20 inc postage Helper springs 2.25"dia 2" open NEW £22 inc postage for set of 4 Coolant pipe from Westfield 1.25” dia. with 3/8 outlets and threaded section for switch. Part no: 12844. £6 inc postage Wheel spacers 19mm thick NEW £10 pair inc postage Vauxhall 744 Yellow Injectors £30 set of 4 inc postage Ignition leads for Vauxhall XE engine NEW set £18 inc postage Engine mounts round rubber from Westfield inc saddles NEW £12 pair inc postage Weber carb chokes 34mm suit Weber 45DCOE NEW £20 set 4 inc postage Weber carb chokes 36mm suit Weber 45DCOE NEW £20 set 4 inc postage K&N crank filter. Little use £10 inc postage Oil seal for rear of XE crank. Payen NB806. NEW £4 inc postage Thanks. Call Tony 07760 285674.
stantman Posted June 15, 2011 Posted June 15, 2011 Interested in wheel arch protectors if they are still available. Cheers Contact details> Jeff.williams@turntown.co.uk
MCB Posted June 16, 2011 Posted June 16, 2011 Rear panel/seat finisher black vinyl £12 inc postage please, I will pm later for payment setails, Mark
westfieldvx Posted June 16, 2011 Author Posted June 16, 2011 ignition leads please. hi westyturbo, I can't seem to send you a message through your contact details so please pm me and I will forward payment details etc. Regards Tony
divingonthereef Posted June 18, 2011 Posted June 18, 2011 Hi Tony, Interested in the following items...can you send pics or pm me if these are available Wheel arch protectors aluminium NEW £10 pair inc postage Indicator lamps (orange round ones) NEW £12 pair inc postage Wheel spacers 19mm thick NEW £10 pair inc postage Cheers MIKE
westfieldvx Posted June 27, 2011 Author Posted June 27, 2011 Hi Tony, Interested in the following items...can you send pics or pm me if these are available Wheel arch protectors aluminium NEW £10 pair inc postage Indicator lamps (orange round ones) NEW £12 pair inc postage Wheel spacers 19mm thick NEW £10 pair inc postage Cheers MIKE Hi Mike, the indicators and wheel spacers are still for sale but the arch protectors have gone. Drop me a pm with your email and i'll send you some pics. Thanks Tony
