wrightster Posted May 9, 2003 Author Posted May 9, 2003 Just rang a place in blackburn , listed as a webcon agent who arent able to do the work !! excellent ..not they can order the parts for me but i will need to supply the part numbers , brilliant again ....not Thanks Paul i will let me show you yours on wed, but i havent ordered the parts yet though - would ideally like to find somewere that will do it for me if i cant but that looks like being a task in its self !! BTW should be bringing a new recruit with me on wed Quote
studbuckle Posted May 9, 2003 Posted May 9, 2003 a spanner, screwdriver, cable cutters and keep Hurdsey talking, i'll have it sorted in a jiffy for you ... assuming I can find the meet Quote
wrightster Posted May 9, 2003 Author Posted May 9, 2003 Cheers Si, just spoke to the guy in blackburn again , they have got a rollin road there which is handy as its only 15 mins away he is going to phone weber technical for me to find out what is involved and get back to me, i am not going to have the parts for this wednesday but will get them ordered next week if ness Quote
Paul Hurdsfield - Joint Manchester AO Posted May 9, 2003 Posted May 9, 2003 assuming I can find the meet Its in MANCHESTER thats M A N C H E S T E R just a little bit west of Yorkshire Quote
studbuckle Posted May 9, 2003 Posted May 9, 2003 Ov'r't 'ills though Might have to reset my carbs to cope with the altitude Quote
Paul Hurdsfield - Joint Manchester AO Posted May 9, 2003 Posted May 9, 2003 Did you say altitude or attitude cos we dont allow no attitude in Manchester Quote
wrightster Posted May 9, 2003 Author Posted May 9, 2003 cos we dont allow no attitude in Manchester aaaaaaarrrrr kidddddd !! Quote
wrightster Posted May 9, 2003 Author Posted May 9, 2003 and a bigger fridge !! (oh and 3d ignition parts please) - just to keep the thread on track Quote
Paul Hurdsfield - Joint Manchester AO Posted May 9, 2003 Posted May 9, 2003 aaaaaaarrrrr kidddddd !! Wassup whacker Quote
Glen H Posted May 11, 2003 Posted May 11, 2003 Sorry to break up the battle lads, Wrightster, When I built my previous car with the Weber Alpha carb kit, I bought the throttle position switch ( used to give 3D mapping) direct from Webcon, if you phone them up and tell them you're set up they will be able to advise you of the part reference, If I recall correctly I paid approx. £35 plus postage. If Marcus is reading he has a set of fitting instructions and part numbers in the build file for his car and my be able to bring such info to wednesday's meeting. As mentioned above you need to get you're carb's set up/balanced first and then fit the switch, this simply bolts on to the carbs on the right hand side and has a moving arm that locates onto the end of the throttle mechanism. A basic electrical multimeter is also required to set it correctly, takes about 5-10 minutes. Glen Quote
wrightster Posted May 12, 2003 Author Posted May 12, 2003 right sorted now, 49.00 for TPS from standard autoparts , 70.00 for rollin road session and about 10.00 for fitting TPS sounds reasonablish Quote
