Don Homer Posted June 13, 2010 Posted June 13, 2010 Anyone know where I can get a couple of these? They are off a crossflow waterpump and inlet manifold. I normally pick them up at autojumbles but have had no luck so far - none on fleabay neither Quote
stewart pickles Posted June 13, 2010 Posted June 13, 2010 raceline put somthing like that on there water rail as a take off for the heater Quote
Norman Verona Posted June 13, 2010 Posted June 13, 2010 If all else fails John Wilcox used to keep them. Quote
pistonbroke Posted June 13, 2010 Posted June 13, 2010 Is that a bsp male to female elbow or to hose end ? should be easy to find at any decent plummers merchants try "plumcenter" if there's one down your way try these Quote
Don Homer Posted June 13, 2010 Author Posted June 13, 2010 It's for the heater take off and return. It's aluminium. Quote
Major Stare Posted June 14, 2010 Posted June 14, 2010 Think i have one at home..... will check tonight Quote
Darkspeed Posted June 14, 2010 Posted June 14, 2010 Burtons stock them. https://www.burtonpower.com/prodLanding.aspx?CCode=PC900 Quote
Major Stare Posted June 14, 2010 Posted June 14, 2010 Just checked.... i have one but its been cut down, so its now in the bin. As mentioned.... Burton Power should have em Quote
