YODA Posted May 13, 2002 Share Posted May 13, 2002 Hello All, Thanks for the advice on wheels I've now got a set for £240. The next item on my list is a set or seats. The car has bench seats at the moment which are in good condition but as I'm only 76kg I tend to move about alot when cornering hard. I can pad out the hip area but there is no support for the upper body/shoulder sections. Westfield do a set for £360-ish, has anybody tried these? or is there alternatives (c******m) for a narrow body car? I will be using a harness rather then a standard seatbelt. Quote Link to comment Share on other sites More sharing options...
JamesD Posted May 13, 2002 Share Posted May 13, 2002 Yoda, The Westfield race seats with the vinyl lining are very supportive, especially good if you have a smaller frame. Those with a larger frame will find the edges of the seat cuts into their hips. They also have the added advantage of looking 'race cool' and have cutouts for 4 points, and are cheaper then the more GT orientated style. JD Quote Link to comment Share on other sites More sharing options...
Martin Keene Posted May 13, 2002 Share Posted May 13, 2002 I use the Intertrim Ranger in my narrow body, trimed fibre glass, high back seat with harness holes if required. They cost £140 ish each from Europa (or £190 for a pair inc delivery if you get a stinker of a deal at a show). The only niggle I have is they are a little bit upright and therefore you might find the need to tilt them back slightly. Quote Link to comment Share on other sites More sharing options...
Nick M Posted May 13, 2002 Share Posted May 13, 2002 Check out the seats from Plays-kool - Plays-Kool . They look pretty supportive and excellent value at £100 each. Quote Link to comment Share on other sites More sharing options...
furtive Posted May 13, 2002 Share Posted May 13, 2002 That URL was so *nearly* right. Play's Kool Quote Link to comment Share on other sites More sharing options...
Mark Stanton Posted May 13, 2002 Share Posted May 13, 2002 Yep - I've just ordered one of PK's carbon jobs. Tried one for size and they've seem well supportive across the shoulders and Quote Link to comment Share on other sites More sharing options...
Nick M Posted May 13, 2002 Share Posted May 13, 2002 Knew I should look at what I type... Quote Link to comment Share on other sites More sharing options...
