a4gom Posted October 4, 2008 Share Posted October 4, 2008 I've seen a few posts recently asking about spring rates so thought it might be a good FAQ, I'm certainly interested. If peeps could post up their proven / recommended combinations I'm sure it would be a useful thread. I'd certainly be interested. Obviously there are a number of contributing factors which we need to know as well as the poundage, these are the ones I can think of so far so fill in as many blanks as you can Front lbs (&colour)= Rear lbs (&colour)= Engine= Narrow/wide= Live/Independent= Road/Track= Weight of car= Anything else you can think of add it on, i've put the colour in in relation to sprongs but I am aware this is not always a true reflection of the rates. If we get enough replies i'll try and collate and add them to the first post. Quote Link to comment Share on other sites More sharing options...
elpks Posted October 5, 2008 Share Posted October 5, 2008 As supplied by factory for SEW with pinto Front lbs (&colour)= 300lb black with dab white paint Rear lbs (&colour)= 150lb red front arb = none rear arb = none Engine= 2.0 pinto Narrow/wide= wide Live/Independent= live Road/Track= road Weight of car= 615kg Quote Link to comment Share on other sites More sharing options...
custardtart Posted October 6, 2008 Share Posted October 6, 2008 94 Narrow SE front - 300 rear - 200 narrow live axle front arb from Procomp rear arb - none engine - 1.8 zetec track 535kg without driver - 625kg with Quote Link to comment Share on other sites More sharing options...
gordonandmaureen Posted October 13, 2008 Share Posted October 13, 2008 i have recently done a check on the rear of my S.E. with westfield supplied parts & here is the result Gaz dampers 14.5inch full extension. closed length inc bump stop 10.5inch. spring red plastic coated uncompressed length 11.5inch i/d50mm 150lb Quote Link to comment Share on other sites More sharing options...
Tim Reid Posted October 13, 2008 Share Posted October 13, 2008 Front lbs (&colour)= 300lb Rear lbs (&colour)= 175lb Engine= 2.0 Zetec Narrow/wide= Wide Live/Independent= Independent Road/Track= 90% Road 10%track Weight of car= Unknow (full weather gear so 700kg?) Quote Link to comment Share on other sites More sharing options...
chappers Posted October 14, 2008 Share Posted October 14, 2008 Front lbs (&colour)= 300lb, 1.9" diameter 7" long black springs on 12 (and a bit) inch protech alloy shocks Rear lbs (&colour)= 175lb, 1.9" diameter 9" black springs on 14" protech alloy shocks (GTS widetrack fitted, though same shocks fit standard /westfield normal track wishbones) front outboard ARB from Westfield (with slightly shortened drop links for GTS widetrack. rear ARB from Westfield Engine= 1.8 Zetec Narrow/wide= 2001 SEiW Live/Independent= Independent Road/Track= 90% Road 10%track Weight of car= 640kg including carpets, weather gear, tonneau, boot full of crap. Quote Link to comment Share on other sites More sharing options...
Hammy Posted April 8, 2009 Share Posted April 8, 2009 I can only say SE narrow, live rear end rear springs 120Ib - as recommended by MT motorsport (road car), when he set the car up. Quote Link to comment Share on other sites More sharing options...
RichP Posted April 13, 2009 Share Posted April 13, 2009 Year = 1995 Front lbs = 400lb Rear lbs = 150lb Engine= X-flow Front Track = widetrack by Procomp Narrow/wide= Wide Live/Independent= Independant, Sierra viscous LSD Road/Track= Mix Weight of car= 596 (no driver, full tank of fuel) And to add: Front camber: 1.1 degrees negative Rear camber: 0.5 degrees negative Front castor: 5.15 degrees Front toe: 1.0mm inwards Rear toe: 1.6mm inwards Quote Link to comment Share on other sites More sharing options...
Dave Eastwood (Gadgetman) - Club Chairman Posted May 28, 2013 Share Posted May 28, 2013 Figures based on spec of car at the time. Front lbs = 275 (7")Rear lbs = 160 (9")Engine= XENarrow/wide= WideLive/Independent= IndepenentRoad/Track= Mainly roadWeight of car= 585 kg This is for the aeroscreened car, no heater etc. ARB's fitted. Quote Link to comment Share on other sites More sharing options...
AdamR Posted May 28, 2013 Share Posted May 28, 2013 Front lbs = 350 (8")Rear lbs = 185 (9")Engine = XENarrow/wide = WideLive/Independent = IndepenentRoad/Track = Mainly trackWeight of car = 590 kg This is for an aeroscreened car, no heater etc. PlaysKool ARB's fitted and set to almost full soft, full cage, 888s or ZZR tyres. More info: http://forum.wscc.co.uk/forum/index.php/topic/97318-spring-selection-calculation-quick-help-morhps-into-general-setup-thread/?hl=spring+rate Quote Link to comment Share on other sites More sharing options...
Geoff101 Posted May 28, 2013 Share Posted May 28, 2013 Narrow SEi CrossflowFront lbs = 300lb FaulknerRear lbs = 180lb Faulknerfront arb = nonerear arb = noneEngine= 1700 x/flowNarrow/wide= Narrow (with standard track front)Live/Independent= IndependentRoad/Track= RoadWeight of car= 560kg Quote Link to comment Share on other sites More sharing options...
Steve_Farrimond Posted June 12, 2013 Share Posted June 12, 2013 Front lbs = 325lb (1.9" x 7")Rear lbs = 200lb (1.9" x 9")front arb = nonerear arb = noneEngine= 1800 zetecNarrow/wide= wide (with standard track front)Live/Independent= IndependentRoad/Track= Road mainlyWeight of car= Quote Link to comment Share on other sites More sharing options...
JOCKER Posted August 17, 2013 Share Posted August 17, 2013 2.0 Zetec with newly fitted Protechs Front lbs = 325lb (1.9" x 7")Rear lbs = 200lb (1.9" x 9")front arb = nonerear arb = noneEngine= 2000 zetecNarrow/wide= wide (with standard track front)Live/Independent= IndependentRoad/Track= Road mainlyWeight of car= No idea Quote Link to comment Share on other sites More sharing options...
DamperMan Posted September 16, 2015 Share Posted September 16, 2015 Very interesting... As a new owner and engineer at Spax I was going to ask what sort of range of Springs folk are using to base some new development on. My 95 CVH SEiW has tested 288Lbs/" presumably supposed to be 300 on the front and 200lbs on the rear. I removed the 20 year old original Spax dampers and fitted with New ones I built myself last night. I intend on doing a far it of damper development on this car. I also find in interesting how much its mentioned about needing to balance dampers on this forum. I agree dampers need to be matching but, from my experience if all the components are good and the dampers built well there should be very little difference in performance between dampers. Thats all folks Quote Link to comment Share on other sites More sharing options...
lewis Posted September 17, 2015 Share Posted September 17, 2015 Quick question. I got my springs and protechs from WSC. I have black springs on the front and white on the back. What spring rate are these? Front lbs = ?Rear lbs = ?front arb = Nonerear arb = NoneEngine= 1800 MX-5 NANarrow/wide= Wide (with standard track front)Live/Independent= IndependentRoad/Track= Road/trackWeight of car= ~600KG Quote Link to comment Share on other sites More sharing options...
