greeny 0 Posted February 24, 2007 Share Posted February 24, 2007 Methods of Changing Gear by William Hewland The following is some info regarding shifting gear and face dog wear. I am in the fortunate position where I have a good amount of knowledge on the subject, as I understand the mechanical side and the user (driver) side equally well. N.B. For succesful gear shifting, remember that it is critical to ensure that all mechanical elements between the drivers hand and the dog faces are in good order and properly set. This includes the gear linkage in the chassis! Successful up-shifting, (defined as fast and non dog-damaging) will be achieved by fully moving the dog ring as rapidly as possible from one gear to the next, preferably with the engine's driving load removed until the shift is completed. (The opposite is true of a synchromesh gearbox as used in passenger cars, where slow movement helps). It should be remembered that it is not possible to damage the dogs when fully engaged (in gear). The damage can only take place when initiating contact during a shift, (the `danger zone`) therefore this element must be made as short as possible. If a driver moves the gear lever slowly, or if the linkage is not rigid and effective, dog wear will occur. We always recommend lightweight yet solid rod linkage, not cables ideally. I list below the different methods of up-shifting that are used in racing most commonly. The best at the top, the worst at the bottom: Automated (semi automated). The movement of the dog ring is powered and the engine is cut / re-instated in a co-ordinated manner. Gear-shifts take milliseconds. This system produces zero dog wear when set up well. It is not applicable to most cars, but it illustrates that speed of shift is a good thing. Manual with engine cut. This system is almost as good as an automated one as long as the driver pulls the lever very quickly. Again it is not applicable to many cars, but it illustrates that speed of shift is a good thing. A `cheat` version of this is to shift on the engine rev limiter, which can work well. With this system it is especially important to move the lever ultra fast, otherwise the engine will be reinstated during partial dog engagement, causing damage. The damage can usually be felt by the driver. Manual. Best method: With no assistance from the engine management, the driver must lift off the throttle sufficiently to allow the dog ring to be pulled out of engagement. He should then stay off the throttle long enough to allow the dog ring to engage with the next gear. In practice, the driver can move the gear lever faster than he can move his foot off and back on to the throttle. Therefore the effective method is to apply load to the gear lever with your hand and then lift the throttle foot off and back on to the pedal as fast as physically possible. In lifting your foot, the loaded gear lever will almost involuntarily flick to the next gear before the foot is re-applied to the throttle. Another method is to load the gear lever with your hand, stay flat on the throttle and dab the clutch to release the dog ring. The overall effect on the gear shift is similar to the above method, but clutch wear may become a big issue. The worst method (most destructive and definitely slowest) is to attempt to change gear in a `passenger car / synchromesh` way, i.e. lifting off the throttle, dipping the clutch, moving the gear lever, letting the clutch up and re-instating the throttle. The method causes unnecessary clutch wear, does absolutely nothing to help come out of gear and usually causes dog wear whilst engaging the next gear. This wear is due to several reasons. Firstly, it is impossible for a driver to co-ordinate the complicated sequence of all five physical movements accurately. Consequently the engagement dogs often find themselves engaging whilst the throttle is applied. The lever is usually pulled more slowly as it was not pre-loaded, lengthening the `danger zone`. Successful down-shifting, has similar rules applied regarding speed of shift. Unloading the dogs is done in the opposite manner obviously. Whilst braking, the dogs must be unloaded by either touching the throttle pedal or- my preferred method- by dipping the clutch. However, one sharp dab of clutch or throttle is appropriate per shift. Continued pressure on either will cause dog damage for different reasons. `Blipping the throttle` just before engagement is advisable if the rev drops between gears are over 1300 rpm, as this will aid engagement and stabilise the car. TOP TIP for ease of downshifting: Make the downshifts as late as possible in your braking zone (i.e. at lower road speed), because the rev drops between each gear are then lower. So many drivers make the mistake of downshifting as soon as they begin braking, causing gearbox wear, engine damage and `disruption` to the driving wheels. This is a subject which can be much expanded on, but I feel that these are the basics, which I hope are of use. Quote Link to post Share on other sites
Mark Hughes 13 Posted November 29, 2020 Share Posted November 29, 2020 Cheers very informative, I've just moved to a dog box and found this very handy. 1 Quote Link to post Share on other sites
Andrzej 195 Posted November 30, 2020 Share Posted November 30, 2020 Mark and others - can You share Your experiences regardig using dogbox in parking / slow / on-off trailer / slow driving in 1st / changing 1-Reverse etc ? I have heard some opinions that there are some nonexistend in synchro boxes "problems" ? I wonder what is the principle for gear lever movement in slow driving ? - in race conditions it is adviced as above to use rapid gear lever movements. But what about parking / road driving / slow cooling lap on track etc ? Quote Link to post Share on other sites
Mark Hughes 13 Posted November 30, 2020 Share Posted November 30, 2020 Hi, I've only driven the car a few times so far, all on the road, manoeuvring at slow speed in first is identical to a syncro box. going into first or reverse at tickover is smooth. I find blipping the throttle on down changes at lower speeds say approaching a roundabout and using the clutch smooths it out. Seems rare that you get a clunk when it engages, but it does give mechanical clunk now and again. Up until I read the feature above I wasn't aware you don't use the clutch on shifts up or down, so I'm on a steep learning curve! 8 hours ago, Andrzej said: Mark and others - can You share Your experiences regardig using dogbox in parking / slow / on-off trailer / slow driving in 1st / changing 1-Reverse etc ? I have heard some opinions that there are some nonexistend in synchro boxes "problems" ? I wonder what is the principle for gear lever movement in slow driving ? - in race conditions it is adviced as above to use rapid gear lever movements. But what about parking / road driving / slow cooling lap on track etc ? 1 Quote Link to post Share on other sites
Paul Aspden 128 Posted December 2, 2020 Share Posted December 2, 2020 On 30/11/2020 at 10:31, Andrzej said: Mark and others - can You share Your experiences regardig using dogbox in parking / slow / on-off trailer / slow driving in 1st / changing 1-Reverse etc ? I have heard some opinions that there are some nonexistend in synchro boxes "problems" ? I wonder what is the principle for gear lever movement in slow driving ? - in race conditions it is adviced as above to use rapid gear lever movements. But what about parking / road driving / slow cooling lap on track etc ? Selecting gears from neutral can sometimes be odd. If the clutch is depressed and the stick moved in one fluid movement it should be fine, but if there is a delay from pressing the clutch to selecting a gear then you sometimes get the dogs on the gears not meshing. When this happens you can slowly lift the clutch whilst gentley loading the gear stick, as the gearbox starts to move the gears will then mesh. Alternatively, release the clutch in neutral and as you press the clutch, push on the stick at the same time. Other than this, they are just like a syncro box at low speed....its more the lack of flywheel weight and the aggressive clutches that are a problem! 1 Quote Link to post Share on other sites
