Stack Dash system
Nick Algar - Competition Secretary
Stack Dash – Model ST868 designed to interface with the ECU and display the values from there, ie Water temp, Oil Pressure and temp, fuel pressure, RPM, Speed. Unit is in working condition as has recently been tested OK in a working car. It gives predictive lap times as well. Rev counter displays to 8000 rpm.
Wired to work with a Pectel T2 ECU, but believed to work with Delco, EFI, MBE, Motec, Zytek. Uses serial connection. Comes complete with R recorder module, Lap sensor, G meter and wheel speed sensor.
Originally fitted to a Mygale 2lt Zetec engined car, Pectel T2 ECU wiring harness available separately. Originally cost over £ 2000. For sale at £ 950 ono.
