Windy's new project
windy
 Share
Been doing a bit of work in the garage.
Got given a wreck with a number plate that's worth something.
Appears a bit rusty on the floors but actually quite good for a 27 year old car
Outside had some horrible fibre glass arches which were promptly removed and sold on ebay
Link to comment
Graham,
Quit whilst you are ahead!
John  :0
Link to comment
I wondered where the steering wheel off my 205 had gone.
You do know it has to have an MoT for you to transfer the plate...
Do you want the wheel? I still have it if you want to save it from going in the skip ???  :)
Reg is staying with the car.
Anyway here's some progress:
Shell stripped & on a spit.
Found some rot in the drivers side A pillar & floor so new panels welded in.
A repair section for the rotten C pillar was removed from another shell and grafted in.
New sill put on drivers side.
Link to comment
Thorough job as usual Windy - I admire your patience.
I see you have plug wleded along the bottom of the sill - do MoT examiners accept that? If so you've just saved me a lot of hassle.
Chris
Link to comment
Chris
As long as the plug welds replicate the original spot weld positions you are OK. Also remember that you must remove the old panel first - some people just slap another one on top which often gets the MOT man twitchy - I think if they see a bodge that's when they usually say that the repair must have a "continuous weld".
Shell is just being repaired at the moment. Once the rally bits go in it'll all be seam welded.
Link to comment
I always think a mig-plug is stronger than a spot weld , some spot welds just ping off when you prize them apart   :0  If you"ve  tried to take of a panel that has bin migplugged on you will agree  :D  :D  :sheep:
windy..  agree that looks a thorough job.. are you  trained doing this sort of thing or taught in the school of life   :t-up:
Link to comment
Look a fairly tidy shell.  Bit Envious I still like old escorts. Years ago I did a Mk1 RS2000, just as panels were starting to run out, but managed to get ford front wings and a front panel (wings were £30ea  I recall...)  Worst part was the inner wings which required a lot of patching (strut tops, drip rails, suspension cups, and thel ower bit where it is welded to the for and aft box section. Took me nearly 3 yrs.
Interesting bit of the rear wing you've replaced -accident damaged I guess, funny place to rust!
I wrote mine up for Practical classics and  got £100 with a signed letter from Ms Butler-Henderson (? -the mad woman now on 5th gear you guys all lust over, used to work for Pratcial Classics !).
Tell us more - wot motor you gonna use ? what trim ? what are you going to do with it ( Rally ?)
Link to comment
:t-up:  :t-up:  :t-up: Top Job :t-up:  :t-up:  :t-up:
Link to comment
You can still get nearly all the panels. There's a company called Ex pressed panels that does nearly everything but fairly costly. If you want any bits genuine Ford you have to cut the good bits off scrap cars. Ex-pressed stuff is extremely close to the quality of the genuine Ford panels. Pattern wings from Hadrian are still only £40, the whole front end + 2 door skins was only £250 delivered. I guess providing there is enough demand for these bits, the suppliers will continue to make them.
Rear quarter wasn't accident damaged but i think the rot had set in in the C pillar, then someone bodged it with filler to hide it. I think the water then sat inside because it could no longer drain out.
Its going to get a big power engine, either proper works spec 1800 BDA of Millington / Cossie YB depending on what will be most saleable. Haven't decided yet. Shell will be prepped to Group 4 spec or better. Getting ideas from Colin McRaes car is making me want to make it something special. :D
Link to comment
 Share
