Vx 16v clutch
altval
 Share
Just passed the SVA RAYYYYYYYYY.Trouble is the clutch is slowly giving up the ghost.2.ol 16v Vauxhall mated to a Ford Sierra, 5 speed box. New clutch,don't know where the cable came from. No more adjustment.  Any ideas?????
cheers.:d
Link to comment
Altval, reading your post, (and reading between the lines a bit) I am guessing that you dont know full history. Just a stab in the dark but if someone has modified a Sierra fork instead of ordering one with the bellhousing, it could be that it is slowly bending. Also, check security of bellhousing to engine bolts, if they are loosening you will get the same symptoms.
Link to comment
 Share
