Clive 0 Posted January 16, 2002 Share Posted January 16, 2002 Having now seen this issue raised in several guises, I asked Lumenition if a ballast resistor is needed with regard to my particular setup, which I guess is similar to other users.......... Optronic system with a Lucas Gold Sports coil. Their reply is as follows: Quote: "The answer to your question is very simple. The Optronic system should be used with a coil of between 3 and 3.5 ohms. If the coil you are using has a resistance of between 1.5 and 2 ohms you will need a ballast resistor." Hope this is of help to others Clive Quote Link to post Share on other sites
