chris 0 Posted January 14, 2002 Share Posted January 14, 2002 I'm running a 91 SEIWide with a Cosworth 4x4 LSD and Spax adjustable shockers (not sure of spring rates). Its currently set to 0 degs camber all round which I believe should be -1 to -1.5 degs negative? What do you think? What shocker settings should I run for track / road use ? Quote Link to post Share on other sites
mb893 2 Posted January 14, 2002 Share Posted January 14, 2002 Depends on lots of things...... Engine/car weight/your weight/tyres/tyre pressure/front to back weight split/CofG/brakes/spring rates/ride height (front to back)/the weather/how uncomfortable your prepared to be and what colour socks your wearing etc... Have a look at my site for the settings I use on my car, but note all of the above. On my car this works (very well) - on yours it might not, but at least its a starting point. My ride height is 125mm back 100mm front as measured on the points in the manual. Regards John The MegaBLADE Site Quote Link to post Share on other sites
Fast Westie 0 Posted January 14, 2002 Share Posted January 14, 2002 I'd use about -1 deg and 4 clicks at the front for the road and up to -2.5 deg on the track with about 10 clicks. At the rear try -0.75 deg and 2-3 clicks. You can play with tyre pressures, but start at about 18psi. Quote Link to post Share on other sites
