mick 0 Posted January 12, 2002 Share Posted January 12, 2002 I am about to replace a failed ignition coil on my 1700 crossflow,fitted with Optronic ignition.Does anyone know if I should use the ballasted or un-ballasted type of coil? The wiring to the coil at the moment doesn,t seem to have a ballast resistor in it,but the wiring in general looks a bit bodged up,so I,d like to sort it out properly.I can,t tell what type the old coil is ,as the label has dropped off. Cheers Quote Link to post Share on other sites
ian crocker 0 Posted January 12, 2002 Share Posted January 12, 2002 The std optronic requires a ballasted coil. The Performance system uses a non-ballasted 'electronic' coil. The very same Q was asked a few days ago - look for the thread as I posted the web site of Lumenition. Cheers, Ian Quote Link to post Share on other sites
