High Tickover Problems Part 2
Buzz Billsberry
Buzz Billsberry
Additional which I didn't mention on the orginal, as follows
when the engine starts the tick-over is @ approx 800 rpm
then rises to 1500-1600rpm as the engine warms up.
The ECU is a MBA 2D system with no TPS, bought from SBD,
Regards  Buzz :cool:
Link to post
Buzz,
so you have no TPS sensor. Can you confirm if the set up used to work fine. Ie you tick over was ok before.
Also can you tell me if the car comes back down to the current tickover quickly or more slowly. does it sort of slowly rev down to it ?
Link to post
Buzz Billsberry
Hi Adrian,
yeah T/O has been fine then all of a sudden raised to 1500/1600rpm and stops there until I start from cold again where it T/O's @850rpm then it steadily rises as the engine gets warm.
Regards Buzz
Link to post
Paul@Plays-Kool
Just established what this problem is today, having got the car to run again.  Both throttle spindles in the carbs are bent & the butterflies don't seat properly.  Looks like a carb recon moment! :)
Paul
Link to post
Buzz Billsberry
Big thanks to all of you for your help over this problem and it looks like Virgil AKA Paul Aspden is the winner!
1st prize is a quality carrott :p
Thanks everyone
Regatrds Buzz :cool:
Link to post
