Edge to carbon sheet
harrypotter
 Share
What is the best way to finish the edge of a carbon dash that sits flush with the scuttle? It would need to be very slim I guess. Or is it ok to just carefully sand it smooth?
Link to comment
I sanded mine to the contour of the scuttle and then use some 600grit wet and dry to give a nice chamfer to the edge.
I'm in two minds as to adding a rubber trim or not???
I would suggest some felt tape or similar on the face off the scuttle where carbon panel meets as it does sound rattly even when bolted/screwed tight.
Link to comment
17 minutes ago, kenton said:
@carbon-nv Not on your website yet but I'm sure many would like your new product designed for this. 😉
Carbon NV is no longer a member, so won’t see this I’m afraid.
Link to comment
Ah, ok.
Mark has a moulded carbon edge trim made to the shape of the scuttle to cover the dash edge. Looks good too. 🙂
Link to comment
20 hours ago, kenton said:
Ah, ok.
Oh dear I feel the wallet opening again ……
have you got one and if so any pictures ?
  • Haha 1
Link to comment
I’ve used nail varnish on the cut edge of fibre glass before. Maybe clear or a black would suit carbon.
Link to comment
I used a 'P' shaped black rubber edge trim. The bulb was only 2 or 3mm in diameter. I glued the stem on the back with Evostick. Other contact adhesives are available.
Link to comment
 Share
