CherryTreeFW Posted November 21, 2021 Share Posted November 21, 2021 @OldStager sent me couple of spare steering rack gaiters (thanks again very much indeed!) after a muse on alternative ways of creating a steering column gaiter to weather proof and tidy up the column/ dash entry point. I trimmed the narrow extension off the first gaiter and widened the hole to a diameter slightly larger than the steering column. The second gaiter had a smooth extension tube at one end (narrower than the bellows section but still slightly wider than the steering column). That fitted snugly inside the first gaiter so I cut that off and slid it inside. The result is that the inner sleeve keeps the outer gaiter centred in relation to the steering column, but neither of them foul or obstruct the steering column. The picture shows the outer gaiter a bit “squished” but I’d just replaced it after removing it to take some pictures - in normal use it sits easily against the dash at one end and the rest of the quick release housing at the other. I’m planning to fit a Mofast steering column surround, to which I will bind the lower face of the outer gaiter, which probably means I can do away with the inner sleeve eventually. 5 Quote Link to comment Share on other sites More sharing options...
CosKev Posted November 21, 2021 Share Posted November 21, 2021 I used Carbon fibre tube and a grommet in dash hole👍 5 Quote Link to comment Share on other sites More sharing options...
Dave Eastwood (Gadgetman) - Club Chairman Posted November 21, 2021 Share Posted November 21, 2021 Two nice alternative solutions. 1 Quote Link to comment Share on other sites More sharing options...
CherryTreeFW Posted November 21, 2021 Author Share Posted November 21, 2021 5 hours ago, CosKev said: I used Carbon fibre tube and a grommet in dash hole👍 @CosKev - neat, and a very good looking dash overall too! 😀 1 Quote Link to comment Share on other sites More sharing options...
Richard (OldStager) Posted November 22, 2021 Share Posted November 22, 2021 On 21/11/2021 at 08:55, CherryTreeFW said: @OldStager sent me couple of spare steering rack gaiters (thanks again very much indeed!) after a muse on alternative ways of creating a steering column gaiter to weather proof and tidy up the column/ dash entry point. I trimmed the narrow extension off the first gaiter and widened the hole to a diameter slightly larger than the steering column. The second gaiter had a smooth extension tube at one end (narrower than the bellows section but still slightly wider than the steering column). That fitted snugly inside the first gaiter so I cut that off and slid it inside. The result is that the inner sleeve keeps the outer gaiter centred in relation to the steering column, but neither of them foul or obstruct the steering column. The picture shows the outer gaiter a bit “squished” but I’d just replaced it after removing it to take some pictures - in normal use it sits easily against the dash at one end and the rest of the quick release housing at the other. I’m planning to fit a Mofast steering column surround, to which I will bind the lower face of the outer gaiter, which probably means I can do away with the inner sleeve eventually. glad it arrived eventually, glad they were of some use. 1 Quote Link to comment Share on other sites More sharing options...
CherryTreeFW Posted November 23, 2021 Author Share Posted November 23, 2021 On 21/11/2021 at 09:50, CosKev said: How many track days a year are you planning? If it's only a handful or less I would say renting a trailer is the best option👍 Indeed - very useful! 😀 Quote Link to comment Share on other sites More sharing options...
CherryTreeFW Posted November 23, 2021 Author Share Posted November 23, 2021 11 hours ago, OldStager said: glad it arrived eventually, glad they were of some use. @OldStager - yes very useful indeed! Thanks again! 😀 Quote Link to comment Share on other sites More sharing options...
SootySport Posted November 25, 2021 Share Posted November 25, 2021 Clever solution, it’s what owning a kit car is all about. I’m looking for a suitable gaiter now😀 Quote Link to comment Share on other sites More sharing options...
CherryTreeFW Posted November 25, 2021 Author Share Posted November 25, 2021 2 hours ago, SootySport said: Clever solution, it’s what owning a kit car is all about. I’m looking for a suitable gaiter now😀 @SootySport - indeed, it’s what I was looking for when I bought my Westy. @OldStager gets credit for providing the gaiters to make the solution - that collaboration thing is also what I love about the Kit world! 😀 1 Quote Link to comment Share on other sites More sharing options...
Barnsley John Posted November 26, 2021 Share Posted November 26, 2021 Removanle steering wheel only 2 more advices 1 i cut out a jerry can platic spout black spiral flexi filler that goes in fuel tank to fill from jerry can to length which was fine des gave me that idea (brakable) I think fred flintstone gave him the idea Now i have a piece of large bore heat shrink ran down shaft warmed up slowly Plus it will cut off if you ever wanted to remove And its gave a nice finish and smooth if you want a pic any one let me no but its self explanatory The first idea i used the wifes jerry can spout she ran out of fuel in car as women do and youve guess it could not refill car Sat outside the beuty parlour for seven hrs till AA came I said why dident you go and have your treatment while waiting for AA love She said i DID Great spare room again👿 3 Quote Link to comment Share on other sites More sharing options...
CherryTreeFW Posted November 26, 2021 Author Share Posted November 26, 2021 1 hour ago, Barnsley John said: Removanle steering wheel only 2 more advices 1 i cut out a jerry can platic spout black spiral flexi filler that goes in fuel tank to fill from jerry can to length which was fine des gave me that idea (brakable) I think fred flintstone gave him the idea Now i have a piece of large bore heat shrink ran down shaft warmed up slowly Plus it will cut off if you ever wanted to remove And its gave a nice finish and smooth if you want a pic any one let me no but its self explanatory The first idea i used the wifes jerry can spout she ran out of fuel in car as women do and youve guess it could not refill car Sat outside the beuty parlour for seven hrs till AA came I said why dident you go and have your treatment while waiting for AA love She said i DID Great spare room again👿 @Barnsley John - fantastic! Hope you’ve got a telly in the dog house! The steering column has got heat shrink on it, I just didn’t like it coming straight out of a hole in the dash. I think I’ll leave the petrol can spout well alone…😂😂 Quote Link to comment Share on other sites More sharing options...
Ian Kinder (Bagpuss) - Joint Peak District AO Posted November 26, 2021 Share Posted November 26, 2021 5 hours ago, Barnsley John said: I said why dident you go and have your treatment while waiting for AA love She said i DID Is that because she's only allowed to spend £5? 2 Quote Link to comment Share on other sites More sharing options...
Barnsley John Posted November 27, 2021 Share Posted November 27, 2021 20 hours ago, Ian Kinder (Bagpuss) - Joint Peak District AO said: Is that because she's only allowed to spend £5? No she nought petrol can Des gave me heat shrink Saved a fiver Who said we are back of the door up in barnsley The old saying which sum chesterfield softys will not have hurd Up here for brains Down there for dancing And of course the old favorite saying Oh no the spare room again She just points now to the spare room dunt say out Just points I only mentioned using heat shrink Now look wat yave dun Quote Link to comment Share on other sites More sharing options...
