woodman Posted October 21, 2021 Share Posted October 21, 2021 This is a damper and anti roll bar package to suit a Westfield sei narrow car ( it may fit others). It would make a very good adjustable set up for track days and fast road use. I used it on my sprint and hill climb car. The dampers are top of the range Gaz ‘mono tubes’ with Ali bodies and spherical bearings. They are unused since Gaz did a full service with new Ali bodies ( I have receipt). The fronts are 300mm centres, the rears are 320mm. There is a pair of red Eibach 275 lb front springs and a pair of black 200 lb rear springs. The anti roll bars are ‘Ash Mason’ designed and come with brackets, drop links and adjustable sliders. There is a pair of front camber adjusting sleeves with raisers and spherical bearing to suit cortina uprights. There is also a pair of brackets to allow the rear dampers to be fitted more upright. I have shown the scuff on one of the damper adjusting rings Price £795 ono Link to comment Share on other sites More sharing options...
