Broken cycle wings
Rexer200
 Share
Like I say, it's tight! it must be on top of anything else in there. The first time t tested it to see, after suddenly twigging why the end of the box was a funny shape, i basically fitted the rail in first then sort of rolled up and tucked the rest of the hood in underneath!
Link to comment
Ok, just fitted the bikini hood in the boot as you mentioned. I'm still glad a bought the hood bag for the roll bar though as at least that way I get the boot back as it was pretty full with just the hood. Hood in the boot is a nice to have option though for certain occasions.
Link to comment
56 minutes ago, Ian Kinder (Bagpuss) - Joint Peak District AO said:
I passed IVA with these fitted and they're much less obvious (when off) .
Side repeaters
Regardless of the legalities, do you want to ensure others correctly see your intentions? Especially given how low down and vulnerable you are in a seven type car.
Thanks, I've just ordered some of these. I'd prefer to be seen and these are just a bit smaller too.
Link to comment
43 minutes ago, CosKev said:
That's the front indicator 🤣
You reckon you can see that from 1mtr from rear of car?🙄
I can see it from here and I’m 100 miles away.
Link to comment
Added lightness!
Just bond the wires with tigerseal to the underside of the cycle wings (having abraded them first to aid adhesion). I've documented the replacement of mine in my build thread here-
Link to comment
2 minutes ago, Ian Kinder (Bagpuss) - Joint Peak District AO said:
Added lightness!
Great, thanks... I'll copy that... Tigerseal on order!
Link to comment
1 hour ago, Rexer200 said:
I can see the indicator 1m from the rear though, that's the point. My car already has IVA so the question was about the MOT not IVA
You asked why Westfield don't use the same lights as on your Caterham, I answered that👍
Link to comment
Don't give up the day job🙄🤡
Link to comment
Trolling on here is his day job! 😆
  • Haha 3
Link to comment
I’ve not got a day job, I retired last year.
Link to comment
I think that means he's an intern! :o
Link to comment
  • 2 weeks later...
@Ian Kinder (Bagpuss) - Joint Peak District AO, I've now received these side repeaters but have noted that I now need to drill quite a big hole in my new carbon wings to for them, whereas the old Westie ones were stuck on with just a small hole for the wires. How did you fit yours?
Link to comment
by drilling quite a big hole in the side of the wing (circa 22mm from memory) I then used tiger seal to hold both the lamp in place and the wires. Make sure you abrade the plastic well to aid adhesion.
Note I've not had any genuine CF items, just two sets of the fake plastic items!
Link to comment
 Share
