woodman Posted August 13, 2021 Share Posted August 13, 2021 I have decided to sell my Westfield Se as an unfinished project. It is a live axle , Narrow SE and was registered as Westfield in 1989. The chassis has been blasted back to bare metal and sprayed black.It is in good condition for its age It has had all the brackets welded on to accept a 'Caged' rollcage. The rear trailing arm brackets have been strengthened Spec includes Full Cage Front wishbones with polybushed inner joints and top camber adjuster with rose joints. 4 x 6"x13" cross spoke , satin black alloys shod with R888R tyres Cortina uprights with discs Alloy hubs mudguard stays 2.4 turn quick rack with uprated mounts Upper and lower steering column Steering wheel and boss 4 x Spax 2.25" adjustable dampers with springs English axle with half shafts ( will need the brackets repositioning) 4 x trailing arms with rose joints one end £3750 ovno (I would sell without cage if not required) I will have lots more parts to sort out and add that will be offered to the purchaser first including 2 x sets bodywork, fuel tanks , floor pedal box, Hi spec calipers, seats, carbon dash, CWP and diffs, propshaft, screen, carpets,etc etc Thanks for looking Stu Link to comment Share on other sites More sharing options...
