CBR1000RR Refresh/upgrade
Simon Waterfall Syman84
 Share
Rest easy Simon, I’ve just checked it with my straight edge, it’s spot on.
must be a camera trick
Link to comment
Must have been the camera angle
Something else i did spot is Rush Motorsport going into the timber business?
  • Haha 1
Link to comment
Covid meant we had to diversify and the carbon fibre market is already popular!
  • Haha 2
Link to comment
Well F1 used to use a plank under the cars so it must make them faster...
Link to comment
Well the old engine was dropped off today and the new engine collected.
thanks to @Alex Gaskin and @Howardfor originally sourcing such a good package of parts.
Quick spec to my knowledge.
it's a 2014 CBR1000RR with billet Superbike inlet cam and HRC valves and springs.
It has a Nova CR A race gearset: 2.4, 2.0, 1.688, 1.5, 1.368, 1.272 ratios. Not sure if I will use these or if I will swap to a standard box and sell the nova gearset as they may be too short for a car application.
It also has the HRC kit alternator.  These are supposed to be good for 3-5 bhp. Engine has been fully rebuilt and reputedly gave 198bhp at the wheel on the bike.
Also came with an AB Performance billet sump off Andy Bates ready for the car application.
Loom and a few other bits and bobs.
Now the work begins to get the engine mounted in the chassis. 4 weeks to go until my appointment for the new manifold to be made.
Crap pictures from collection in the dark. But my smile is big.
  • Like 4
Link to comment
Serious engine 😃
I have the Nova box in mine. With a 3.3 diff and 185/70/13 rear tyres it tops out at 127mph ish. I would defo try and keep the box, depending on your rear tyres you may be good with a 3.14 diff...
Link to comment
30 minutes ago, AdamR said:
Serious engine 😃
I run a 3.38 at the minute so was going to try and calculate it with that and a 3.14.
With slicks for sprinting I run the
200 540 13.
@AdamRDid you just do an excel sheet or use an online calculator
37 minutes ago, Rush Motorsport said:
Thanks to @Rush Motorsport for helping me lift it….
And thanks to russ and his glass back for lifting the engine in the car with me 😁
Link to comment
Sorry for novice-question : how to differentiate std gear set in CBR 1000RR gerbox from this NOVA? one has to count the teeths on the gears or sth like that ?
Link to comment
It's a complete aftermarket close ratio gearbox
https://novaracing.co.uk/2008-2017-honda-cbr1000rr-cr-a-race-gearset
Mainly used in dedicated track bikes. Stronger gearset but normally the ratios don't tend to work in a BEC.
Link to comment
I am asking because just yesterday I delivered a CBR 1000rr engine to the mechanic who is going to investigate for the cause of the water to oil and co2 in  water "additives" in it when working. If its only a gasket or something more serious - cracks in block/head etc.. . Got this engine with MNR car, with not all known history, and I remember the seller said it has special "stronger" gearbox. If it was just talking ? , or maybe not ? - worth to ask a mechanic to look at gearbox, but was not sure what tell him - what to look for.  Thank You for the link, there are ratios and numbers of teeths so maybe this way he can differentiate . Or maybe the seller thought about some stronger clutch, and called it "gearbox" .
Link to comment
From memory it has fewer dogs on the gears
Link to comment
 Share
