Battery neutral connection
DIY-Si
 Share
1 hour ago, DIY-Si said:
They are Simon's fog and reverse lights I think.
Correct, I have the same but have run their loom on the chassis with only the rear clam lights going through the connector.  I've also use a pair of red LEDs (same design as the one's you've used as repeaters) as high level brake lights on the top of the 'Le Mans' hump. The repeater through the aluminium side panel is very close to the 500mm height minimum so make sure you adjust the ride height before the IVA.
  • Thanks 2
Link to comment
 Share
