NickBW 283 Posted Tuesday at 20:49 Share Posted Tuesday at 20:49 Hi All I am trying to work out which of my fuses is my Ignition and start fuses Ignition A -5 Start B -4 My fuses are different capacity and when i pull the ignition fuse in A-5m turning the key still starts the ignition Here are my fuses. Is anyone able to help? Thanks Nick Quote Link to post Share on other sites
Ian Kinder (Bagpuss) - Joint Peak District AO 4,985 Posted 20 hours ago Share Posted 20 hours ago 14 hours ago, NickBW said: Hi All I am trying to work out which of my fuses is my Ignition and start fuses Ignition A -5 Start B -4 My fuses are different capacity and when i pull the ignition fuse in A-5m turning the key still starts the ignition Here are my fuses. Is anyone able to help? Hi Nick, I suspect you're getting ready to convert to keyless ignition/start? The starter solenoid is only protected by the 60A main fuse on the loom usually mounted on the diagonal chassis rail above either the driver or passenger footwell. Mine is near the water bottle location. If you're following my keyless guide- the fuse A5 is used by my design to power the relay used for the starter. Hence it will stop you cranking once you've completed the mod, if you remove the fuse, but with the factory wiring with the ignition switch, pulling the fuse won't stop you starting! The factory fuse designation above, shows B4 as Engine/Ign. This is the power to your ECU, so will stop the car running/starting. Does this help? 1 Quote Link to post Share on other sites
NickBW 283 Posted 15 hours ago Author Share Posted 15 hours ago Yes it does. Thank you! 1 Quote Link to post Share on other sites
